Lancastrian
Len,
Excellent recovery. A lot of work for you but certainly worth the effort. Well done.
Ian
Ian
make sure you roll the boiler the right way round not inside out, like some idiot didI have now put on the Chassis detail overlay.
While I am posting, how do I put the index on the front of the post so I can go to the last post and add to more posts?
Len
I’ve been trying to find the time to finish off a guide on thread marks. Currently it’s in draft but I’ll try to make the effort to publish it, hopefully that will help.I have tied that but it made no difference, I don't now if you need to do something else.
Len
If you are not picking power up from the track then no. The hole is to pass a wire through to the pick-up.I have got to this stage of adding the dummy hornguides, but if it is battery operated do I need to do this?
Len
Personally I would lightly tin the rear of the hornguide plate and then sweat it onto the chassis using the ERSA station, only because I don't have an RSU, if you have an RSU then it would do the job just as well. [ I have had 2 RSUs but never found a job for it that I couldn't do with the ERSA station so sold the RSUs - but that's another story!]It's been 4 months since I last posted (too hot) now it's a bit cooler now (a bit warmer than England though). I am in a bit of a quandary, how do I fit the horn-guied to the chassis (I have a flame, Exctoscale resistance soldering station and a ERSA soldering station) any idea of what to do?
Len
Hello Len,It's been 4 months since I last posted (too hot) now it's a bit cooler now (a bit warmer than England though). I am in a bit of a quandary, how do I fit the horn-guied to the chassis (I have a flame, Exctoscale resistance soldering station and a ERSA soldering station) any idea of what to do?
Len
