Len,
That’s bad luck.
I suspect this is due to the frames being soldered together whilst one side is hotter than the other, and when it all cools down, the contraction is uneven, and that pulls it into a curve. If it’s straight say for 60% of the length, and just curved at one end, you might be able to give it a quick dose of heat over the curved end and if you’re lucky, it’ll settle down.
I’d use a blowlamp, but that’s a bit drastic, particularly if other things are going to drop off.
Otherwise, you’re going to have to progressively unsolder and remake the joints.
That’s bad luck.
