SimonD’s workbench
There’s a post on the 3D printer thread if anyone is interested in how FEPs are replaced.
Fluorinated ethylene propylene (FEP) is a copolymer of hexafluoropropylene and tetrafluoroethylene. It differs from the polytetrafluoroethylene (PTFE) resins in that it is melt-processable using conventional injection molding and screw extrusion techniques.[2] Fluorinated ethylene propylene was invented by DuPont and is sold under the brandname Teflon FEP. Other brandnames are Neoflon FEP from Daikin or Dyneon FEP from Dyneon/3M.
FEP is very similar in composition to the fluoropolymers PTFE (polytetrafluoroethylene) and PFA (perfluoroalkoxy polymer resin). FEP and PFA both share PTFE's useful properties of low friction and non-reactivity, but are more easily formable. FEP is softer than PTFE and melts at 260 °C; it is highly transparent and resistant to sunlight. (Wikipedia)
Well, you did ask... :))
In this context, the FEP material is used to create the flexible transparent drum-skin that forms the bottom of the print tank, and through which the UV light pattern is projected to create the image on the print plate. You can see part of it in the image in my post 1861 above - I suppose it looks a bit like tracing paper but it is very much more flexible. Indeed, very like a non-stick drum-skin.
Dangerous Davies
the thought of PTFE being heated worries me. Are we talking about low-ish temperatures which it doesn't break down? I ask because of the risk of hydrofluoric acid being released and the associated health hazards.
I worked in a steelworks producing silicon steel (3% Si) for transformer laminations. We used HF in our pickle line where it was treated with utmost respect.
Keep up the good work
Dave,
thanks for the comment and concern! I would be most averse to cooking PTFE and well remember the dire warnings regarding overheated o-rings in the Ford development labs in Dunton from my days in the auto industry. PTFE (and Viton) o-rings are of course used in live steam models and the risk of overheating is certainly something to be aware of.
For folks who do not know, overheated PTFE will release hydrofluoric acid which, even in very small quantities can cause very damaging skin burns which are particularly difficult to treat. If in any doubt whatsoever, handle any overheated o ring (or other similar components) with rubber gloves, bag it and bin it along with the gloves, and wash anything it may have touched with plenty of water.
there‘s a link here https://www.alliedsystems.com/pdf/LongReach/Bulletins/LRSB0003.pdf which suggests that there’s a real, but rather remote risk.
in respect of the FEP on a 3D printer, it gets up to a pleasantly mild 25 degrees C, and that’s very much at the safe end of the scale.
best
So instead of FEP, I decided to break my Unimat :(
happily turning some wheels on a coarse scale 3R impulse purchase into something suitable for 0MF when I was interrupted by a loud “bang” and a smell of the smoke getting out of something which I expect is/was a capacitor. It still runs, though it doesn’t feel like a good idea.
I shall dismantle and investigate…
Meanwhile, @Giles, I believe you had an alternative solution involving sheep? Could you please point me in the right direction?
thx
Giles
Those particular motors I got about 30 years ago - so not on the market..... but I do have the original Unimat motor which I won't be using again? Otherwise I would look for a DC variable speed 200W motor of whatever voltage......
oldravendale
thx
That seems a bit cruel, particularly in today's enlightened world. Anyway, you'd have to build a treadmill and capture a sheep both of which will probably take a while.... I look forward to seeing the gearing to get the speeds you'll need on the lathe.
now, let’s see if we can get one of these or something similar. Not sure what it actually is/was…
trying to read it in a sensible direction, I have
(D) (S) 25 / 085 / 21
SW
Y= gn/ge (There is a diagram to the left - looks like two switches, five connections)
bl
[ERO] J3
F1740 - 325 - 5522
0,025uF X
+ 2x2500pF Y
250V ~ 4A
560-7 HPF (There is a logo to the left - looks like “VDE” in a triangle)
-25 / +85 C
R57
It has five connections, two blue, two black and a green/yellow presumed ground.
the uF and pF confirm my suspicion that it was a capacitive thingy, I guess to shift the phase of the field, but it’s not my domain.
it’s not well, in any case :(
Must be the START capacitor.
That I get (phase shift to create a rotational torque effect from windings) but I don't get why some 1phase motors also have RUN capacitors?
Well, lots of references on the www.
Entstör-Kondensator ERO Typ F1740-325-3511, 0.025 µF + 2x 2500 pF / 250 V~, NOS | eBay UK for example, however, I find it extraordinary that seven other people are looking at this in the last hour….
And this suggests a separate box might be the simpler approach. Five wire XY suppressor - UK Vintage Radio Repair and Restoration Discussion Forum particularly as old capacitors don’t fade and die, they go bang…
I’m not sure why they need a start and a run, and I’m no longer sure that’s what this is.
but we have a tame electronics guru at work. He’ll know, and he’s kind enough to put it words I understand too :)
more soon…
michael080
As it seems to be a suppression capacitor, I would assume that the motor has some kind of commutation. A starter capacitor would be used if the motor is a shaded-pole type
As the name says, these suppresion capacitors are used to suppress sparks that occur between the commutator and the brushes, mainly if the brushes move from one commutator segment to the next.
Your motor would run without this capacitor, but your TV- and radio reception may be quite bad as long as the motor runs :cool:
Thanks Michael,
I had seen the term “suppressor” in the vintage radio thread, but I’m far from clear about how to wire it in, given three capacitors and five wires. Three wires would have been clearer, but which way to fit the caps? It does run with it in its current, rather unhappy, form. If it is commutated, there are no external brush holders, so the brushes may also not be in the first flush of youth!
Hopefully I’ll know more tomorrow. It would not be difficult to have a small enclosure on the back of the motor with a couple of external capacitors inside. Wiring will be fiddly but feasible.
Meanwhile, I have located a speed-controlled motor with roughly twice the power for £159 which is tempting, and Giles has been most helpful.
best
smgee
Thanks Michael,
best
I believe using a 24V electric scooter motor is a popular upgrade/replacement, combined with a switched-mode speed control. I've seen a thread somewhere, which I now can't find! Ebay seems to have motors in a range of power outputs, e.g. 150W for about £20, or a complete kit for £130.
Thanks Dave, the website is very helpful.
I have the motor in bits, the brushes are ok, but there is a lot of muck in there, which I need to clean, and I can then trace the wires.
My cap is not a pass-through, all the wires come out of the same end, but I don't think that's an issue.
Will pop up a diagram when I can
thanks again
