One of the things about this hobby is that it isn’t all about what colour, which loco, what date, etc.
Sometimes the diversions are fun, we’ve enjoyed many a frivolous rabbit hole over the years and long may it continue.
Sometimes, they’re bloody frustrating, as in a box of 8 3DP wagon “kits” that did not survive the tender ministrations of DHL on their way to Nick
@magmouse . I’ll spare you the photos, but if you told me they’d played rugby with the parcel, I’d believe you. They certainly converted the contents.
And some things are curious. I have suffered a few print failures, then runs of good prints, then runs of failures. This morning was another fail…. And then the printer would not turn on again to allow me do a tank clean. The button was prodded and pushed and poked and in the end turned on, I sorted the tank out, recovered most of the resin, and grumbled a bit. Then the dumb thing would not turn off. Google. Ah, Saturn 2 power button, known, if not common, failure mode. Dismantling was not easy, but we got there in the end. After several attempts to stop the push-push button from sticking, I unsoldered it from the little PCB to which it was mounted, drilled a hole through the Power button, fitted a toggle switch and put it all back together. “ Reassembly is the reverse of disassembly”
Which is why you need an electric drill, and superglue…
it seems to work, I shall test it properly once the dishwasher has completed its cycle.
