Clarence3815
Thank you.
Thank you. I use a Saturn 8k but I don't think I regularly acheive that sort of quality.Just a pair (third stood down waiting for repair) of clunky old Saturn 2 (sadly it no longer appears to be in production, I should have bought a couple of spares to future proof when I had the chance) and Siraya Tech Fast Navy Grey, in this instance the 12K version.
I'm pretty much wedded to the stuff, it has its faults but overall it's pretty bomb proof once you have your settings dialled in. I've seen other peoples results with different resins and they look better in many respects but then appear to suffer in others and I've got a couple of bottles of those to try at some point.
You never really know if the issues are down to the resin or down to that person's machine or their settings until you try it for yourself, problem is, it can take quite some time to dial a new resin in.
FNG is very detailed but does/can suffer from surface artifacts, it's also quite strong but at the same time brittle if flexed too far, it also has a tendency to shrink over time, typically 8-10 months. There are other resins that are smoother but less defined in detail and others that shrink less.Thank you. I use a Saturn 8k but I don't think I regularly acheive that sort of quality.
You give me far too much creditExquisite work Mick!
You've really elevated soldering to an art form and your CAD and 3D printing skills allow you to lift your builds to a level which is way beyond what the rest of us can achieve.
Peter
I use as much solder as anyone, more in some cases; the only difference is that it's inside in hidden spaces where possible. Sometimes you have to deviate the build process to achieve it but the end result is less cleaning up outside.You give me far too much creditI use as much solder as anyone, more in some cases; the only difference is that it's inside in hidden spaces where possible. Sometimes you have to deviate the build process to achieve it but the end result is less cleaning up outside.
There's a good reason for that, the more I have to tidy up the less £/hr my rate becomesI think we all try to do that, but you're just better at it!
but it's easy to file off and blow in tomorrow.
Interesting, that'll explain the black finger tips when trying to glue, I thought it might be the paint off the drum whence it came.Probably a moot point now, but the coating on Fireline braided fishing line will rub off over time, at least for the black color. What's left is something that feels a lot closer to normal thread, and you may be able to successfully glue that. I don't know know how long it would take to rub it down on purpose, but it might be worth a try. I also don't know how other brands of braided line behave, I've only ever used Fireline.
Conversely you could look up a video on the type of knot used to tie line to a fishing reel spool (Google says Arbor knot). It's essentially the same application as the drum on the crane.
Well that sort of worked better than expected, the original 4lb fishing line was much too thin so went up a bit to 100lb; some good and some bad points with it. It is a good representation of steel rope and forms nicely but it seems to be waxed so you can't glue it to the drum. I ended up making a little hook and soldering that to the drum and then winding the rope on, making sure the mechanical fixing is at the bottom out of sight.
They’re all to thin Dave, I’ve got 0.9 mm on and it looks about right, the elastic stuff I think is called Shirring elastic thread and that’s what comes in the kit, there was some left over in the box the crane came with……I left it there.To represent cable traditionally one would have used black cotton and beeswax to stop fraying. The alternative to the fishing line would be model boat or aircraft rigging. Rigging Thread | Fine Thread for Aircraft and Ship Models
Cheers, that was the challenge, to match what was there and not go over the top.The bogie looks like it has always been there. Maybe a bit better definition than the original kit but doesn't catch the eye at all. The cables look good. If you had another one you could display your customers models like this -
or maybe not. Article published in the Saturday Observer in Brisbane on 8 July 1911, they weren't scared to include technical information.
, though building one yourself is a different matter to repairing someone else's work for several decades ago.I think that's the best that we can hope to achieve, representative, as there doesn't seem to be an exact miniature copy available, all of them have pluses and minuses so it's pretty much personal choice.Well to my eye, looking at the model and what you have done, does look very representative.
Paul
