This week has all been about spinning the plates a little faster and stepping up a few gears; that'll continue to increase over the next few weeks to try and claw back a lot of the time lost earlier in the year on other protracted builds.
The Connoisseur B12 was first on the slab, the tender was completed and a good start made on the engine. On the tender I replaced all the etched flat beading with D section of appropriate sizes, it's a small thing but a nice detail to have and I can't remember the last time I built a kit and didn't have to replace anything.
I deviated a little bit on the engine, it's designed as fixed axles so I dropped the leading and intermediates out and swapped in some etched fold up sprung units, that's fine until you try to add the big stay over the leading axle; slitting discs, fret saw and files to the fore and notches cut to clear solved all that.
The only other deviation was some 3D brake hanger castings to bulk up the kit piece of wire poking out of the frames.
The bogie is a simple affair and the leading top hat bearings are visible from low angles so I'll draw up some faux axle boxes and slip them over the top hate bearing stub to dress it up.
There's one very tiny error in the instructions with the intermediate brake beam and pull rods, but it's a five second fix so isn't really a problem, other than that everything just fits
