Some gentle work over the festive period, DA S&D 7F to be precise.
Pretty much straight out of the box to be honest, the 7F tenders were very basic and as far as I can tell not scoop fitted, hence the single stand on the footplate for the handbrake. a couple had the more modern front end with coal doors and lockers but this one (#7) did not.
I spent 10 minutes cleaning up one of the white metal axles boxes/springs and then looked at the other five, sod that and pressed print, they'll be spat out tomorrow some time and fitted.
The tablet catcher still needs to go on and a blanking plate over the hole in the footplate where the scoop stand would normally reside.
There's two holes in the top of the lockers I'm not sure of their purpose as yet and the two on the front bulkhead below the shovel plate are for the water supply gate valves, I have a print for the flange done already and will add the levers later.
The coal space will be full of coal so no need to get het up about being neat and cleaning in there, work smarter not harder.
