John,
Same problem here.
I have just assembled two sets of gear for my 4-4-0s. Both had binds once the gear was in the frames Each of the moving parts were individually fitted and kept in their pairs. Connecting and valve rods were fitted to the crank pin or eccentric so that they always fell to vertical under their own weight and the cross heads slid under their own weigh if upended.
However once all assembled there were problems, quite noticeable on the rolling road with stutter and change of sound. It took quite a while of tinkering to discover where I had introduced the problem. In my case it was the eccentric rods and their connection with the expansion link which was the source of additional friction. I found that a bit of twist had got into the rods such that the pins at the small end were not quite parallel with the eccentrics. This caused a tight spot when the rods were in one particular position.
My rods are fabricated with the little ends silver soldered on, leaving the rods annealed and quite soft. The solution was to twist the offending rods but it took quite a number of dismantling/assembling sessions to get everything sweet.
You may have something similar and the only way to find out is just to keep fiddling. I know from experience that when it comes to the final assembly, after painting, there could well be another sticky bit. The joys of modelling!
Ian.
I think the twisting you refer to is my problem too, however my twist, I think, is coming from a different source. the eccentric sheaves are wider than the eccentric rod clasp around them, allowing for a bit (too much) sideways movement. As they slide (probable not much more than half a mm), this causes the expansion link to 'wobble' vertically, and I suspect this is where the problem lays. Before I start altering my CAD drawings, I'm going to try and fit some packing pieces on the eccentrics to try and reduce that movement and see if that help. I might try using some thicker wire as pins holding everything together at the expansion link end too, just to try and make that end a bit less loose too. I've only soft soldered everything, so a bit easier to take apart![]()
The washer idea is where I was heading. Having got everything in primer, I think I'm going to paint everything as the next job - more as a change of scenery more than anything. I'll get back to the motion after that.Hi John,
Yes that could be where the trouble lies. I made the eccentrics and the straps the same width. My eccentrics are plain with no flanges and the four straps keep each other in line. When I assembled the straps, with 16BA screws, I rubbed each side on Emery paper to ensure the joints were smooth and to give a bit of running clearance.
1/2 mm is quite a bit but you could try a temporary washer from a twist of wire to see if that cures the bind. If that works you can make it permanent with a proper washer but you may have difficulty fitting it. Two half C shaped washers could be clipped over and soldered together, hot iron low melt solder quick,
Ian.
Yes, just like that
Thanks!Sudbrook was from memory Severn Tunnel way so was the MW used during construction of the subterranean bore? More importantly very nice model John.
Martin
