lancer1027
Yes please mate. although i will double check the radius etc and get back to you.
Rob
Rob
I've got a few ideas, have you got a picture of what you mean?Impressive. You really are getting the hang of this arnt you. Have you ever thought of doing Bridge abutments and Bridge holes particularly the later newer types ie the ones with steel girders under them.
The rule is a 7mm scale so the window bars are more or less a scale half inch. I've used 1mm MDF and it's surprisingly robust.
...How about 40012 AUREOL ?, with crest ?...
I hadn't realised until your pic of Aureol that these modern plates have virtually no radiused corners between flat and raised parts, so the fabricated lasered plates become very realistic - unlike the old kettle plates where the absence of radius is very noticeable![]()
Not so, just depends on who made the original master, steam name plates can have bevelled edges or sharp edges and some diesels also have bevelled edges though generally they are more sharper…..
I was sure all steamer plates were radiused!Thanks Mick, that was an eye-opener!I was sure all steamer plates were radiused!
But yes, as always, it pays to check reference material if you can.
It's a setting on the laser thankfully, but it doesn't show up when painted. The overrun is a feature to ensure all the lines join up, however here it was set too high. 0.01mm actually.I can't help but notice the introduction of a feature not seen before on your superb brickwork - the mortar appears to have been cut out in preparation for renewal by an over-enthusiastic builder's mate on a re-pointing chisel gun
To what extent this is a problem with a finished painted building I have no idea. Maybe none. Is the cause something to do with excessive speed of lasering causing over-run or oscillation of the laser head at end of travel? Is there an easy fix?
Other than that the job looks great!
