Rob Pulham
That looks excellent Phil
I have, and I've tried to draw a representation. Have you got any designs in your book?Phil,
Had any thoughts about air bricks ?, these were used on buildings that had timber floors and would add some nice detail to model buildings.
Col.
What you have written is what I expect to see given that the lowest rows carry the most water so the fewer the vertical "joins" the better the resistance to water getting underneath the slates.The difference I can see is that on my double layer, I've turned the lower layer by 90 degrees as this is what I found on the web. Is this incorrect practice or is this like the half tiles at edge something that changed over time?
That's great. I've designed and laid the roof with a double layer of slates on the bottom row and the slates are triple layered at the theoretical battens. In the case the battens are 1.75mm wide.
The difference I can see is that on my double layer, I've turned the lower layer by 90degrees as this is what I found on the web. Is this incorrect practice or is this like the half tiles at edge something that changed over time?
BTW, where is this building you are working on?
Much of what has been posted here about this subject is in line with the way in which the slates were laid on my 1890s property - duly noted when I replaced the slates, with new ones, circa 1975. The most interesting bit, not yet appearing here, was the method by which the flashing was fixed in the adjacent brick wall using skew-cut timber wedges.
Jim, I'd forgotten about that thread. Brilliant work. Have you got any recent pictures of you model?
At least it would have made my job easier if I hadn't had to cut and bevel every damned slate individually.
I think if I do another slating job, that it will be on a higher class type of building where high quality, matched size slates were used, then a laser cutter would be ideal, doing strips of slates like you have been producing.
