Simon H
What points are you using, Rob? I'm guessing either the "medium" (12" radius) or Setrack (9" radius) Peco.
The layout I showed with the Rapido wagons on it uses the Setrack points, but not everything plays well on them as they're dead frog. I haven't been able to try a Sirdar on them yet...
I remember seeing Roy Link's original, ¼" scale Crowsnest in Railway Modeller when that issue came out, it must have been one of the first micro-layouts, though they weren't called that then. Aside from railway modelling, at the time I was also making up and adding detail to the Matchbox 1:76 AFV kits with their little diorama bases; Crowsnest to me seemed to combine the two varieties of modelling.
Simon.
Flaxfield
Simon.
Hi Simon.
I'm hoping to use one 'Y' point, a Peco SLE 497. I'm not keen on the Code 80 rail, and would prefer something lighter but I don't want to faff with building track etc so it is what it is.
I agree regarding Crowsnest. That's what attracted me to the idea of a really simplistic layout, which when you actually looked, Crowsnest was anything but, with each element being extremely well thought through and beautifully executed.
Rob
Simon H
Hi Simon.
Rob
Unfortunately, there's never as far as I know been a realistic prospect of finer 009 track from Peco, in the manner of the N gauge (and, latterly, TT:120) Code 55 with its double based rail...I remember some natter about it in the 1990s but it never came to anything. Some 009ers have used the N gauge Code 55 track, cutting out alternate sleepers which is doable as the track base is pretty robust, but it's a bit of a faff.
Part of the problem is that until fairly recently much 009 still used ancient chassis with deep wheel flanges. I haven't tried the Shinohara track that @alastairq has linked to above.
The Peco Crazy track can actually look pretty good, provided it's suitably disguised with paint, ballast, and other subterfuges...that Y point is a pretty good choice.
Good luck!
Simon.
Simon H
For what it's worth, I've downloaded and printed off the Peco 009 point templates and ordered some Code 40 rail (f/b). I'll have a go at making my own points with the Code 40 rail in due course. Fortunately, the Rapido flange profile will be fine for the Code 40 rail, soldered onto copper clad sleepers.
When I built some track and points based on the Hudson "portable" track 30-odd years ago, I used Peco Code 60 f/b...a bit chunky, but the stock I had both then and now would run on it whereas I thought Code 40 might be pushing it a bit!
I think the wheels on the Rapido stock look excellent; perhaps the availability of RTR stuff of this quality will lead to some better ready to use track becoming available?
Simon.
David Hall
Simon.
A good friend of mine builds his own track using code 40 rail. It looks superb! See some photos here:
Castle Caereinion
However, you can get Peco track to look quite OK with weathering though. Something like the Clyre Valley Railway would be a perfect example. As weathering and colouring of your track and ballast is a real forte of yours Rob, you will make the bog standard Peco stuff look fantastic.
Now, here’s an idea, Tim:
Why not knock up a point and some short lengths of plain track when the rail eventually arrives, and send them to Rob?
As a Tuning Fork, I understand that all that’s required is a single point, a longer section of plain track for the headshunt and two shorter sections for the sidings.
It would be an ideal test to see if it’s a go-er, and if the stock doesn’t like it, it would save you a great deal of heartache and unnecessary work, and then Rob could revert to using proprietary track.
Just a thought.
Jon
Flaxfield
Morning, all.
I now have the required Y point ( SLE-497 ) and have been spending quite a bit of time on researching resin and the noble art of pouring said same.
Of the resin aspect of the project itself, I have two thoughts.
Plan A is to infill the ' cove' and leave it at that.
Plan B is that I create an island within a 'puddle' of resin. The latter would require more resin, plus mould, and be a lot bigger ( and I suspect more fragile )
This is meant to be a simple, cost effective project so plan A is clearly going to accomplish that objective better than plan B..Plan A is of course going to be easier to transport, which is important.
Colourwise, the 'water' will be a Mediterraneanesque turquoise or light blue. Proper funky, highly improbable but perfectly in keeping with the rather preposterous nature of the layout.
Rob
alastairq
Will it be referred to as the 'slice?'
I would be inclined [tipped up?}....to find a rectangle of strong [rigid?] perhaps plastic, or the stuff they make signs out of....just a bit larger than the 'slice?'
'Water' can be simulated by colouring the exposed places...maybe even [using Halfords Camouflage sprays, perhaps?] alering the colours to represent 'water' in some parts, and 'dry land' in others?
Perhaps not making too big a deal out of it....much as a theatre would have?
Indeed, why water? Why not, simply, mud? [low tide?]
