Genghis's 7mm Workbench
Nearly there. Needs vac pipe (included in the loco kit, ladder and buffers).
Having said that, I do have some bits left over........... never a good sign and I haven't a clue what they might be. Still some work required on teh rear right hand tender side/back join.
It’s common to have bits left over, they’ll probably be on a common sheet for several tender types and not required for yours :thumbs:
Genghis
Dave Sharp came up with the answers. For those who will be building a BR1B/C tender, the following aren't identified in the instructions:
034 either side of ladder at bottom platform
048 either side of ladder at top platform
054 engine lubricator handles
060 unknown
103B under 103 if required
111 unknown
I will see if it is worth trying to fit 34 and 48.
Dave Holt
Looks like you resolved the question of where the grease lubrication pipes go from the blocks.
Dave.
Genghis
Too late now but for historical reference.
Never too late before painting............
One issue is that the nipple blocks are very close to the brake hangars. Getting the tight bends in the wires to clear the hangars was difficult. I used .45mm copper but may see if I can get some thinner.
Thank you!
I'll mull over next steps while dodging the typhoon that's about to hit Taiwan.
