4mm Monks Ferry LNWR
As promised, a brief update on the plastic signal ordeal.
As it turned out, removing the cranks and cramps wasn’t quite the ordeal I was expecting.
A very early (crack of dawn) start before pending family visits to celebrate Father’s(Grandfather) Day, saw me snipping off the pivots at the rear of the signal, left of generous length to allow sufficient surface on which to apply s’per glue. Transpired that the glue hadn’t travelled far enough into the hole provided fora good fix and so it was a simple task to push them out using a needle. Due to only the slightest amount of cement having been used to secure the cramps on the front face of the signal to avoid the earlier unwanted bonding of crank to cramp, I recall three of them coming away with the pivot, the remaining being removed with the knife blade.
If I’d considered the previous day’s construction an ordeal, it was nothing compared to the catastrophe ahead. To say threading on operating wires to these tiny cranks without the pivots falling off and trying to remember which went where as they kept moving around, even with the use of tweezers (a hindrance more than a help!), was a fiddle would be an understatement. Then trying to attach the pivots to the trimmer without something moving out of place ……….. Anyway, to cut a long fiasco short, I managed to burst the hole on two of the cranks in the process. Attempting to glue just shrivelled ‘em. It was obvious that their use was a bum steer, and that’s how that modelling episode yesterday ended. As I shut up shop for the day (breakfast), it was apparent that if I were to use these signals, it would be back to plan A: please see the (clumsy) example in my previous modelling photo. Frankly, I was a bit lost at this massive disappointment and wasn’t really sure where to start.
But after the Day’s joyous festivity, I developed a more positive and robust approach to this quandary, and an APB put out for a missing (or remains of) a Finney kit proved dividends after it was recovered lurking between some railway books in my wardrobe. What it was doing there is anyone’s……..
To save waffling and giving a full itinerary of bits, please see the accompanying photo:
It was apparent that if this was to have any chance of working, more materials were required , so before I climbed the stairs to Bobos, I’d left an order with Wizard’s for some handrail knobs, handrail wire and tubing. Still not sure whether I’ll use the tubing as it might look a little clumsy, but as I’m already finding, wire alone as a fulcrum might not be up to the job. We’ll see.
In the meantime, I’ve gathered a couple of the four handrails in the packet and a piece of very thin wire which was enclosed (0.45mm?), and which turns quite freely within. As an experiment, I’ve grabbed the shunt bracket signal (a bit more room to practice with than the more complicated bracket) and placed the items on the trimmer to see if my mind modelling was a go-er or just the usual bum steer.
A start was made using the holes provided in the trimmer which I opened gradually to a millimetre. I think it’s probably more like 0.9mm for the handrail bases but the drill set doesn’t have one unfortunately.whilst it would make gluing them more effective, it’s a bit of a nuisance playing with them as there’s a tendency for them to lift out of the holes whenever I’m anywhere near them eg when threading the very thin wire through the eye holes. Anyway, as ‘a picture paints..’, here’s a photo to give you a better idea than my rambling:
Frankly, I’m not sure whether the (only piece thin enough) wire is long enough fir the job, but as I won’t be able to get back to it for a couple of days after today, Iwant to try and make a little more progress to see whether it’s a go-er, so will probably press on with it.
Incidentally, the little brass brackets on the fret in the picture are what I’m hoping to solder to the ends of the wire, the outer holes having to be opened up to accommodate the stouter steel wires in the kit. There also a couple of bits I’m hoping to use as brackets to go between the handrails to prevent unwanted travel. These parts are so tiny, what’s the betting I gum everything up with solder……. I’ve ciggy paper somewhere and some ancient three in one lurking on the shelf in the garage which I’m hoping will assist as a (can’t think of the appropriate term at present).
Hope all that helps, and many thanks once again for your kind and welcomed interest.
Fingers crossed.
Hmm….
I fashioned a jig of sorts from balsa to seat the components whilst wire threaded:
It worked for the collars, but once handrails were in place it proved useless for fixing on the cams at the end. Not the best soldering result but will work. I think fir the bracket signal/doors I’ll opt for cams soldered to tubing for ease.
Then I customised two of the parts on the fret to act as cams:
The holes were too far apart for this job so I drilled another closer to the end and opened it out to hold the steel operating wire. There were four other smaller ones on the fret bu I’m saving those for the bracket.
The results:
Yep, not my best hot-bitting but I’m going with it.
At least the apparatus can afford 180* of movement which is more than the plastic cranks in the kit could, and probably more than required.
I’ll remove them next and wash off the flux before gluing the knobs into the holes in the trimmer. I might fit the operating wires before gluing - or may not. I’ll see which is easiest.
Thanks for reading.
Phil O
Hi Jon,
Don't take it too hard, we all have days when it would have been better to stay in bed. Take a day off, do something different and regroup and come back to it refreshed. I always have several jobs on the go and if something starts coming apart, put it down and look at something else and if it's after 3pm, it's time to go and have a couple of beers, and leave it until tomorrow.
Hi Jon,
Wise words indeed, Phil :thumbs:
The temperature in the garden whilst working on the signal became a little unbearable which didn’t help so I gave up earlier than intended.
Ideally, a third handrail knob in the centre would add aesthetically to the appearance (the delicate wire became bent with all the work on such a short length of wire which I guess was inevitable) but I’d have to build up the height of the trimmer around the new hole in order to do so to match those either side. This would risk hindering the free movement achieved and thus operation of the signal, so when it comes to a choice between looking good and working, I’d choose the latter any day of the week. Still, I aim to improve things by removing some of the lumpy solder (Carrs 145 I find occasionally lumps up unlike rosin cored which I prefer, but I think requires a higher temperature - perilously so with such delicate objects in a relatively small space), followed by manipulating one of the end cams with pliers to ensure a ninety degree placement to the wire. Once the handrail knobs are glued on, I can use my smooth faced pliers to try and straighten out the wire between to resemble something more like the earlier pics.
But this won’t be until Friday at the earliest due to commitments; the break as you advise but without the beer :(
Best
Jon
Sweltering perhaps, but a free afternoon was too good to miss: apologies Phil @Phil O for ignoring your good advice, but when I’ve an itch…..
Since I last wrote, Wizard Models kindly obliged with a swift delivery and examining the contents filled me with renewed vigour.
Into the bin has gone the previous clumsy attempt at a rotating shaft thingy, to be replaced by stouter nickel silver wire in plentiful lengths and longer knobs. Frankly, the stouter wire would have served on its own as it resisted pressure far more robustly than the thin brass stuff of last, however, I needed to address unwanted travel between the knobs as before. As originally intended, I pressed the brass tubing into use which was easier to solder and looks better than undernourished collars of my previous attempt. Once more, the redundant brass fret was pressed into service, again customising the holes and spacings. Whilst I did well soldiering on in the heat while cutting out the parts, I eventually finished off crafting inside as tiny parts whizzing off into the garden was not only frustrating (no chance of tracing them) but I was mindful of the decreasing number of parts available on the small brass fret.
Anyway, here’s the result:
As you can see from the second shot, the longer knobs (and using the moulded raised holes on the trimmer) allow me to place the hole in the cam for the operating wire(s) nearer to the trimmer which not only looks better in my humble, but also keeps everything more in line.
I’ve since glued the knobs in place and can confirm I’ve been blessed with free movement along the mechanism.
Thanks for reading.
Phil O
Jon,
Good to see that you have some progress with this signal and things are now going 8n the right direction. Always excellent service from Wizard, I wish some of the other suppliers were as good.
Jon,
Thanks, Phil.
Wizard were notably prompt on this occasion. Most pleased.
Jon
Having decided to use the plastic arms which came with the kit (despite having two packs of brass parts from Wizard, the corrugations, if I may remind you, have to be formed using 0.3mm brass wire - which I don’t have - that have to be soldered onto the arms, so took the easy route of using the plastic ones which have them moulded on), I thought I’d strengthen the holes provided in the face of the arm for the operating wire with some collar/spacer thingies found on the spares fret. So that’s where I started the day.
Having cut them and shaped them, my intention had been to glue them on to the perimeter of the hole. However, the lack of meat on the brass collars made this difficult without gluing everything together. I realised quickly that this was a non-starter. The only thing for it was to dig out the brass parts and see what I could muster. Before doing so, I decided to reinforce the plastic bearing on the post/doll, so opened it up with steadily increasing drill bits until a section of brass tube ( 0.9mm) could slide in. Thankfully, I did so without bursting the plastic. It was then super glued in:
I the began cutting lengths of nickel silver wire to length, forming a ninety degree bend at one end to fit in the holes provided in the fret. Then I began the slow repetitive task of soldering and carefully removing each from the fret, before tidying them up with a glass fibre pen and files:
The arms were then joined to their spectacle plates using wire and a track pin poked into a section of balsa previously drilled for the task. I’d decided that I’d use a piece of 0.45mm n/s wire which made a snug fit for the bearing in the doll as an axle, so that was soldered on in the balsa jig. I lost count of how often I had to clear the holes of solder………:
Yeah; looks okay, but please don’t tell the proper modellers that I’ve used oversize wire…….
A trial fit:
I quickly realised that something was amiss.
I searched umpteen photos for reassurance/guidance of how the arm should look, before reluctantly returning to the instructions accompanying the frets. I’d cocked up…… again! The darned things were suppose to be soldered to the REAR of the fret……. Why on earth did LNWR have to be different? Why on earth didn’t they just use flat arms like everybody else? Why didn’t I just read the bloody instructions?
How am I gonna cope with the Crewe Special build……..
Working into the evening, and thus reducing light, I restarted the corrugations with renewed vigour. This bloody thing wasn’t going to beat me!
I suppose looking at this with a glass half full outlook rather than half empty, at least I had the spare fret which came as a surprise with the ratio kit. It’s the best that can be said.
Anyway, I’ve three of the arms constructed; hopefully will finish the fourth tomorrow afternoon.
The new one mounted on the shunt bracket (will glue on the ring after it’s painted separately):
Thanks for sticking with all this drama.
‘Dual controls’ fitted to the bracket signal at last:
Please ignore the offcut of wire seen. Its purpose was to test free movement of the mechanisms.
This time, I’ve not glued them into the trimmer; this will make it easier to fit the operating wires which I’ll measure and fabricate next time.
Thanks for looking.
I wanted to complete the job of fabricating the operational wires on all four signals before priming so made an early start.
Unfortunately, I ended up spending all my time faffing about with the bracket signal. It started off well: the right hand signal took most of the morning but got it working with a full range of motion. However, try as I might, the left hand one wouldn’t play ball. I forget how many wires of varying lengths were cut then abandoned. A mere millimetre or so makes a significant difference to the range of movement; even its direction. Additionally, the mechanism on that side could have done with being a tad longer, the loops on the ends of the wires creating unwanted friction. But you just know when you’re beaten although I gave it my bestest.
So, it was a rethink. Thankfully, as old as it is and not as practical it could be, the Ratio kit has sufficient posts supplied to provide different options. Thus I’ll use separate posts for the roads either side of the middle platform, and the single sided bracket intended as a shunt signal will be redeployed to the single platform. The failed bracket will utilise its working signal replace the shunt signal in the bay.
I’ll finish with a couple of pictures of the failed bracket, showing the range of movement:
I’d have preferred a great range of motion of the arm, but this has been restricted by use of the parts in the kit. The benefit is that it will stop the weighted arm from flailing. The wire between the mechanism and the arm will ne cut to size next time and removed for priming/painting.
Cheers for now.
As a footnote to my last, I might just try a couple more ideas before totally giving up on the double bracket signal.
It had occurred to me the other day that it might have been less congested if I’d set the second mechanism on the rear side of the trimmer. Not confident in my skill required to fabricate the necessary bends around the post (or even whether the wire might not be up to the job) I’d dropped the idea. However, in relation to my doubts about the wire, I’ve been using the N/S wire I bought thus far which is easier to thread rather than the stouter steel wire supplied in the kit. Perhaps if I swap to the steel?
In addendum, it further occurred to me while faffing about with the wires that if I offset the cams at each end, rather than having them parallel, it might afford me a little more range of movement within the restrictions of using the weighted arm and bracket in the kit, as mentioned in my last.
Food for thought and worth a go if only to satisfy my curiosity.
Apologies for a post without piccies.
Btw, Rails have written to say that my ‘faulty’ Precedent has been repaired and tested. Having since bought a replacement, I’ve decided to opt for the return of the original and return the new replacement via their returns policy. Will be most pleased to have it back and working, so am really grateful to the retailer for giving me the option.
Credit where it’s due.
Put into practice some of the ideas (well, a couple) that I touched on in my last in a final attempt to achieve a working bracket signal with two arms.
Once more the Finney spare fret came in handy after I customised a couple of tiny brass parts as before to form the cams on the ‘mechanism’. Thus the opportunity presented itself to put the first of my thoughts into action, cams: one up, one down instead of parallel as before, the idea being to afford a greater range of movement restricted by the bracket of the weighted arm in the kit. Working with the tiny parts in a cramped environment to achieve this end proved a challenge to say the least although I succeeded in not gumming everything up with solder. More down to luck than skill.
Frankly, once I began threading on operating wires I’m not sure it was worth the effort or even made a blind of difference, but I had to explore it.
The bent wire round the doll aspect, the second idea - which was make or break as operating from the other side of the trimmer was the only option of making the second arm work - did prove fruitful, although not wishing to push my luck too far after two or three successful bends round the doll which seemed to work okay, I took the easy way out and resorted to soldering on the final section which connected it to the cam on the reverse side. I snipped off the excess but will probably revisit to remove a tad more. I’m considering fabricating handrails like those in one or two pictures I’ve seen of these signals which should distract the eye. I hope.
Anyway, less of the waffle and a piccie or two to show where I’m up to:
The initial signal arm and operating wire were removed for ease of access (kept falling off!), and the full range of motion on this second signal is not apparent as I’m waiting for the polystyrene cement, which has glued the plastic bracket for the weighted arm to the post, to go off but initial testing is positive.
The signal arms will have to be removed in any case for priming and painting after cleaning off the flux. The mechanisms on the trimmer will a,so have to be cleaned of flux residue.
Incidentally, the mechanism on the trimmer on this side is skewed due to careless drilling by myself from the front side, not realising that I might have to use the holes in the reverse as has been the case. I think once painted and the signal landing and railings have been attached it should hopefully be not so apparent.
A little further forward at least and pleased that the bracket can be utilised as I’d hoped.
Thanks for reading.
Just a brief update, which you’ll no doubt be relieved to hear!
Glued on the bases to two of the signals yesterday, after drilling hole(s) for operational wires to descend below baseboard level.
Took the opportunity of digging out some tubes from the spares box which are leftovers from GWR versions of the Ratio kits. They not only assist in siting them (I’ve a drill bit of required size to drill baseboard so they’re a friction fit) but are also handy hand-holds for spraying/painting:
The shunt signal with it’s unbalanced single doll was always going to be a challenge to dry straight and true:
Will have to unglue and try again with a stouter support under the trimmer/bracket.
Cheers for now.
It’s been another frustrating day, exacerbated somewhat by the good weather (my free time seems to coincide with the heat these days), but thankfully a constructive one.
This really is a challenging aspect of modelling with all sorts of pitfalls which tend to strike just when you think you’ve overcome one hurdle. For instance, after several go’s, you finally cut a length of wire to the right size, one that provides free movement. Then you attach a second, and you discover the first one needs amending/adjusting after all. So you mark it (tends to wipe off as soon as you remove the wire…..) so you repeat the process, mark it again and success, your bend is where you think it needs to be. Then, the wire snaps and you have to start all over again. Then trying to thread an axle through the bracket whilst trying to line it up with the weighted arm between bracket and post, then with the hole in this side of the post, then trying to route it through the hole to the rear which you discover needs redrilling, all the while the operating wires either side of the axle ( which have to be thread on first to gain any chance of ever fitting them!) risk falling off ass you do so….. And so it goes. I think you can grasp the general idea.
One thing that did work, and I found necessary was to place an extra hole in the weighted arms so that the operating wires at each end could operate free from the post which created unwanted friction which was the case using those in the moulding.
Anyway, enough of the depressing stuff and a couple of hastily shot vids to show where I’m up to:
The ends of the axles have been superglued into the rear of the posts and next time I’ll trim them along with operating wires. When using brass weighted arms, I’ve found that they can take the stress of bending the ends of the wires in an effort to stop them falling off. I’m unlikely to do so in this case as if the plastic weighted arms are anything like the cranks in the kit, they’ll burst as soon as any force is applied. Heigh ho.
Thanks for looking and cheers for now.
Hurrah! That looks like not one, but three good results. No progress here of late. Back soon!
Most kind, John.
Thank you.
However, still some way to go with disassembling in part, cleaning, priming, painting and putting it all back together with fingers crossed that the operating wires stay in their holes.
Then there’s the dodgey task of soldering on the back binders once it’s all painted. Ciggy paper and three in one/olive oil will be on call!
Hope you eventually manage to find some time for modelling, John.
Cheers.
Jon
I can report that priming is now complete.
Metal parts were primed first with a couple of coats of an appropriate primer, and left overnight. Finally, the plastic parts were given a couple of coats of acrylic primer.
Some ancillaries (plastic):
I’d hoped to have replaced those in the kit with some spares from Wizard, but could I find them……
The arms and detachable wires:
They’ll be given a day or two to harden before receiving an all over undercoat of Matt black acrylic via the air gun.
Cheers fir now.
