Free 3D Models for download from the Great Northern Railway Society
Mick LNER
Printed for me by a friend , nice kits, mine have brass roofs.
I am not sure if they ever had the Cast Fish/Fruit Plates fitted. The Tatlow photos I have based mine on do not show them fitted.
Mike Trice
I have put up a new 3D model on the GNRS website (GNR Director’s Saloon (D14) – The Great Northern Railway Society). The model represents the GNR Director's Saloon which can be printed in original condition as built by the GNR or as refurbished and preserved on the Bluebell Railway:
The model above was printed on an Anycubic Mono X resin printer, orientated at 25 degrees on the Z axis and parallel to the build plate. At 25 degrees it just fits on my build plate (with some clipping of the support rafts) and reduces considerably any stepping. The model has been given a single spray coat of Autotek Filler Primer.
The model is supplied as a kit of parts with individual parts being capable or being orientated to suit your printer.
The printed model has had the ends, sides, roof and all partitions combined into a single unit with the underframe being printed separately.
Mike Trice
A new 3D Model has been uploaded to the GNRS 3D Models free download area: GNR 9 Ton 6 Plank Open Wagon V01 – The Great Northern Railway Society
The model represents a GNR 9 Ton 6 Plank Open Wagon comprising 9'6" wheelbase, 15'0" over headstocks and 5' doorway. Unlike previous uploads I have also included pre-supported versions of the files all of which have been proved on my Anycubic Mono X using Anycubic ABS-Like Pro 2 resin. Since printing the model below I have added optional 3D buffer heads to the model. Hope you like.
Mike,
How do I use your 3D model to create a 7mm scale wagon?
What was the build period for the prototype?
Thank you, Graham
Mike Trice
Mike,
Thank you, Graham
The model is 4mm scale so it will need scaling by 175 %. I suspect you would be better off adding your own supports rather than using the pre-supported files.
Photos suggest they date back to 1911.
Mike Trice
Basically the underframes started with single brake block operated on one side only to two brake blocks operated from both sides but from the same end to the version in my model with two brake shoes, operated from both sides from the right hand end.
There are certainly some 4 plank wagons on the earlier arrangement but I have not seen a 6 plank. At various times the GNR marked the earlier arrangements obsolete.
No idea on dates.
Mike Trice
Typical! You wait ages for a GNR Open Wagon then three come along in quick succession:
GNR 9 Ton 6 Plank Open Goods announced a few day ago:
A new GNR 9 Ton 4 Plan Open Goods Wagon:
A new GNR 9 Ton 5 Plank Open Coal Wagon:
All are available for free download and use (subject to Creative Commons CC BY 4.0 (Deed - Attribution 4.0 International - Creative Commons)) from:
All models are to 4mm scale but should be capable of being rescaled as required.
Models shown were printed with Anycubic ABS-Like Pro 2 Resin on my Anycubic Mono X resin printer. Some stepping is evident due to me using a rather course 0.05mm layer height. Models have been given a coat of AutoTech Filler Primer and feature Bachmann Split Spoke Wagon Wheels.
One thing I forgot to mention in the earlier post, these latest models include pre-supported versions of the parts suitable for printing in 4mm scale for those that just want to try printing them and building pre-grouping wagons.
