4mm Llanfair
LarryG
A very good friend delivered a birthday pressy this afternoon in the shape of a DCC sound Accurascale 57xx. The scale height splashers make all the difference...
Code 100 doesn't look so bad. The chunky rail fastenings lend it a 'bullhead' appearance...
Amazing how all these years later one can still see evidence of an old broad gauge siding in the yard (note sleeper undulations in the yard surface).
Presumably when the GWR converted the branch to std gauge they did away with the old 7ft siding.
LarryG
Brunel actually carried out a broad-gauge survey of the branch between Welshpool and Llanfair, the other surveys being standard gauge. The line was eventually constructed narrow gauge of course, but I've chosen one of the standard gauge plans, with embellishments!
The line from Shrewsbury to Welshpool is joint LNWR/Cambrian anyway, but my 'history' is the LNWR insisted on a heavily built formation, which was normal for them, and so the branch to Llanfair is the same. Gives me the opportunity to run an Austerity 2-8-0.
LarryG
Most of my ideas pop up while lying in bed in a morning. This morning, I decided to take the loop outside of the shed. The scenery will be far less complicated, and the sound-fitted locos will sound like they are coming from somewhere else...
Dai88D
Funnily enough, i was thinking just before I saw this post wherher you’d venture outside again! You did this with an O gauge incarnation?
Muddysblues
Larry oh oh !!! you might want to hold onto that O gauge shed I just bought …. have you got my bank detail incase you want to refund me :rolleyes:
Craig
LarryG
It's hard to believe the foundations for my shed were laid down 20 years ago on 17th April 2006. And I still haven't a working layout.... :rolleyes:
Shortly after, an Austerity was purchased and detailed to match one I fired at Lees MPD. I didn't know about model railway forums and so Peco Code 100 ruled..... :D
