Flaxfield
Larry, I do wonder if the goods shed is in the wrong place altogether. Looking at the last images of the small shed, even if you choose this shed over the larger brick built job, when say, vans are placed in front for loading/unloading etc, the rolling stock blocks the view from the signal box.
What if the goods shed was removed altogether ?
Then the current good shed road could be straightened, perhaps to end at an end loading dock. The rear road becomes a coal siding.
The goods shed now moves across to sit on the siding opposite the station building on the siding leading off from the loop. Tight but it looks from the photos as if it might fit.
OR ( referring to the last photo above )
Move the goods shed back to where the red lorry is to improve sighting from the signal box.
OR ( sorry )
Again referring to the last photo, truncate the rear siding roughly level with the end of the goods shed nearest the camera. Straighten the current goods shed road and push the goods shed back, towards the back scene. That would open up the view a bit.
Rob
OR ( sorry )
Rob
