Wiring, fellow Westerners, continues in earnest though regularly it seems interrupted by the mundanities of life and requests from family to help with myriad jobs, from leaky showers to those that involve the use of drills - at which I’ve become particularly adept during this build! Incidentally, had use of a ‘proper’ drill used by the trade, and oh, what a difference to the Black & Decker/DIY chains’ own brands in my previous and current ownership. An absolute pleasure to use; I could have gone all day drilling random holes in masonry to my heart’s content! However, having been informed of the price, I doubt one will ever join the mis-match of cheap’n’ nasties of the Jonte tool shed, but still, it was nice while it lasted (I could have waxed lyrical there but really, over a drill?).
It’s true, in my experience, that every cloud has a silver lining because without the unwanted distractions, things could have got a bit sticky. Literally.
You see, if I’d carried on trimming to fit the soldered-on wires as intended, I wouldn’t have been able to lif track an appreciable distance from baseboard to spread the glue. Now I know I wrote that I was to shy away from glue because it masked my hard fought datum lines - since then I’ve realised that the track seems to hold its shape since being slotted together which pretty much null and voids that approach anyway- but it suddenly occurred to me that as I’d already decided to adopt the @LarryG method of lay ‘n’ ballast in one go, which IMHO suits the good ol’ Peco stuff better than the somewhat ubiquitous method of fix first, ballast later with dropper and watered down glue, I’d better have an urgent re-think before it was all too late! I should point out here that I think the latter more suited to scale track with its ‘fatter’ but ‘thinner’ sleepers (I know what I mean); Peco Streamline, with its undersized sleepers in every way, seems to be made to look even ‘slimmer’ when ballasted using this method, but I repeat, that’s just to my own beady eye, and not a criticism of those who do this stuff far better than I ever will.
And so I breathed a sigh of relief. Only a couple of wires will now need lengthening rather than the whole darned lot had I not realised earlier!
So, whilst enjoying the early evening sunshine with my nearest and dearest, I thought I’d conduct a simple ballasting experiment involving nothing more than small offcuts of ply ‘n’ rail, some sand recovered from shoes during a visit to a local beach yonks ago for the purpose, a bag of Woodlands’ medium ‘gray’ sourced way before the memory went; and of course a spot of glue. I say ‘simple’, but as I’ve never ballasted before, this could have proved anything but, but thankfully didn’t.
Mixing in proportions of 6:1, sand to ballast - just seemed about right, as I wanted that late BR urban station look which to me looks like not quite ash, but neither fresh ballast, interspersed with ‘bigger’ bits which I think may have been bits of coal fallen from bunkers of passing locos.(?).
This is what it looked like:
This was just after doing and the glue was still wet.
I left some in place overnight to see if it could still be removed, like that removed immediately by blowing away, in case of unforeseen problems during protracted track laying. Will find out later, as visiting family today for Fathers’ Day impending.
Will then prime half of it to see whether the paint looks better on primed or unprimed ballast. If the latter is the case, I will need to prime the track first, of course. Better to find out now.
Remarkably, it looks okay to me so will employ it on the model. Even the web below the rail looks like shadow, apart from the jointed sections, but as this isn’t scale model railway building, I doubt anyone will mind.
Incidentally, I’ve a different type of ballast in mind for the platform area on the other board: ash which smothers most of the sleepers leaving only chairs and rail showing, so I’ll need to get the Chiminee thingy going at some point, which will provide an opportunity to burn some more of that confidential mail that’s been steadily building in my garage.
The unseen benefits of railway modelling hey, fellow Westerners?
Jonte
Edit: Quick update. No leaching from glue if ballast not removed immediately, such that one can do so when glue has gone off. Good to know:
Grey of the ballast can be seen more clearly here.
And a quick spray of primer as mentioned:
Jonte
Jonte
Jonte
