Jonte,
I’ve just studied your photos, and it looks tight to me, but just to be sure, you have connected the blue wire to both coils on each point motor? I don’t have a Peco solenoid motor, but the pictures appear to show two coils, each with two connections. You have a pair of browns to provide the feed, you return needs to be attached to both coils.
It’s difficult to see for sure on your photos.
I know you raided the mower extension lead, but just a thought, rolls of “hook-up” wire aren’t expensive, and using several colours makes wiring, and fault-finding, so much easier! Red for track feed, black for return, green for frog feeds (obviously, frogs are green) blue for point motor common, yellow for point motor normal and orange for point motor reverse, for example. Couple more colours for your lighting and signals…
eg Plusivo 24AWG Hook Up Wire Kit - 6 Colors (9m each)
lots of choice on eBay of course
hang in there, we’ll sort it.
As Simon says, a cheap multimeter will let you check out the circuitry - here's a cheap one on Amazon which will help you out. You don't need to spend a lot of money for the job you want to do.
At least the motor will lift up with the track with this method, so thankful for small mercies
