Eastsidepilot
The centre line of the slidebar bracket shall be 3'-4 59/64"
'old up mate 'aint you a bit too young to be talking in 64th's
....stick that in your CAD system and you'll choke it.Col.
0.4mm give or take'old up mate 'aint you a bit too young to be talking in 64th's....stick that in your CAD system and you'll choke it.
Col.![]()
They did. In 1944 some (memory is 4-5) B-29s diverted to Soviet held territory due to lack of fuel/damage. The crews were eventually returned but not the airframes. Some of the aircraft were taken to the Tupolev factory where one was stripped down to reverse engineer a copy to meet Stalin's demands for an aircraft to attack the USA with the Atomic bomb that the Soviets were developing from information obtained through a massive spying effort (This aircraft would not have the range for the job but obtained technology that could). Within a year the first soviet aircraft was ready for inspection. This was a massive achievement as the American aircraft used imperial thickness materials and alloys unknown in Russia; they also had to develop cloned engines. The Soviet copy was less than 1000lbs heavier than the 120 000lb American aircraft.the Russians built copies of the Boeing Superfortress
Ian is correct. If you want to get mathematical, 1:43.5 is an approximation of 7mm:1ft. The true value is 1:43.54285714285714(approx)!11' = 123" = 3352.8mm ÷ 43.5 = 77.07mm![]()
I have built a DJH A4 with working lubricator so can I do it a second time? I got a couple of whitemetel lubricator boxes from Ragstone Models just got to make something to attach them too!11' = 123" = 3352.8mm ÷ 43.5 = 77.07mm
I have my units set to 8 decimal places, or 256ths if using architectural units. Not because I ever intend to go to such extremes when creating drawings. But rather because for me one of the primary qualities of cad is the precision involved. There's no sense in my opinion in being casual with the numbers when you can be purposeful. I'm also compulsive about things, so I tend to quibble even when it isn't necessary.0.4mm give or take
You can use imperial and scale as such......I think, pretty sure Jim (US) has his set that way.
I presume you're talking about snapping to a grid with this comment? If so, I never ever have the snap on, unless by accident, as it's next to the F8 ortho toggle function key and I sometimes hit F9 by mistake. I prefer to simply draw things as they are meant to be, as Autocad supports the dynamic entry of distances and angles within nearly all drawing and editing commands. It's really quite simple.I've got mine set to 0.05mm which is good enough for etch work as a whole I find.
[...] Some of the aircraft were taken to the Tupolev factory where one was stripped down to reverse engineer a copy to meet Stalin's demands for an aircraft [...]
It was before morning coffee...And for those outside Suffolk..... 11' = 132''![]()
It was before morning coffee...![]()
