warren haywood
Yes it's stunning, first time I had a proper look last night. Sorry about all the clutter in the pictures, had just finished a 10 hour shift, least I'm going for a game of golf now
Nice! Certifiable....absolutelyHi,
I have spent a lot of time over the last couple of weeks poring over pictures of the lubricator pipework on the footplate. I am satisfied that I know where things go (on the foreman's side at least), and which pipes go over or under which.
I have not yet fitted any to the footplate, but have fitted the pipes to the lubricator bodies:
2 x 8 feed, and 2 x 6 feed - same bodies, rearmost feed not used on the 6 way.
Front (4 feed) and rear (6 feed) gravity lubricators.
.... and because I'm in full fruitcake mode, I am making all the unions, clips etc. Here are 3 unions:
The men in white coats are coming shortly.
Superb, I too would be interested in what size pipe, nuts, and tube you have used for those unions?Hi,
What dia are those pipes, the BLP is 0.3 and copper wire which whilst flexible is too flexible in some instances, those look like brass which may be much easier to work with, suppose it depends on what the real engines used, did the LMS use brass oil feed pipes and the SR copper? Important if your going to cut back the paint and polish on the finally model.
MD
In BR days, the pipe runs seemed to be painted, so black and mucky is the order of the day. The originals were copper, but if I wanted to represent that, I would still use brass, paint black and dry brush.Superb, I too would be interested in what size pipe, nuts, and tube you have used for those unions?
Bxxxxr I was hoping to hide mine --- when I next revisit the kitThe bad news is that these photos will go into the instructions and there will thus be no excuse for you all not to do as Richard has done![]()
Finney7 accessory etch E7/50 small pipe fixing brackets. (I'm trying to avoid selling things, but this etch is little known and for modellers who like to clip pipes down is a must have - and a darned sight easier than scratch-building the little blighters)
Transfer paper?Hmmmmmm
That splasher looks like it could be a bit awkward to line![]()
Hmmmmmm
. I must admit that as I was doing this I thought of you. Still, it will be grubby and grimy at the back, so any imperfections (perish the thought) will be disguised.
