7mm US model dabblings
Are there automotive paint supply companies in the UK. A place where an auto body shop might go to get paints, custom or otherwise, for refinishing fixed up dents? They usually will supply to the retail customer here. And I believe they also can do the custom mixes in spray cans. The only potential issue is that I believe these are usually solvent based paints so may need to be sprayed over a barrier on plastic shells. Applying to metals shouldn't cause any issue at all however.
Jim
Jim, there are several places that match paints if you know the code, the only issue I think would be the conversion from US paint codes to UK paint codes, the colours I'd like are in the BS381 series, but there are many other series, including RAL, I'll have to cross reference them all and see which one comes up best. But at the moment I have BS381 104 Azure Blue (tested ok) and BS381 356 Golden Yellow (not tested yet).
The problem is neither of these are an exact match to Floquil colours which are supposed to be the accurate orignal colours. Both of these I have as an RGB colour not a RAL or BS colour, I should of explained in detail earlier in that I don't think automotive paint shops can match colours from RGB values.
Regarding solvent based paints, I usually blow over a thin primer coat first, they tend to be plastic safe and give a good base for the top coat, in fact Halfords do a specific plastic bumper/fender primer as a base coat for their cellulose top coats.
Mick,
There's an automotive place near me that does exactly that - rattle cans to RAL numbers.
Richard, I've used Doncaster Autos in the past (Warrens tip off) and the service is great and the cans spray really well, I'm just about to ring them and see if they can match colours to a RGB code as opposed to a BS381 code.
But, if you've had success with someone else, then by all means post them up here, I'm open to all sources of paint suppliers, especially if you've had good service from them.
Jordan or Plymouth Mad
Mid-Western Thunderer
Returning from France last week, and seeing at least 10 miles of stationary lorries on both sides of the Channel Tunnel, I'd tend to agree with you Brian!
Tim
(apologies for HiJack)
The small matter of the French Eurotunnel "workers" being on strike again (bless 'em) was nothing to do with it, of course.... ;)
If rail is viable in the UK companies will use it; witness how busy the Daventry DIRFT & nearby Tesco/Malcolm sidings are, but only for bulk/long distance moves.
Rail freight in the UK is hampered by many factors, ranging from the Beeching legacy, through a tiny loading gauge, to an overcrowded, passenger-dominated rail network, & much more besides. It's never going to be like the USA.....
.... which is why - desperately trying to get back ON Topic - some of us prefer to model US outline. ;)
richard carr
Mick
We used a place in wimbledon to get cellulose paint made to order, I will dig out the details.
My preference is to get a half litre of paint rather than cans. I then spray this with a small spray gun diluted 4 parts thinners to 1 paint. It works really well and is miles cheaper in the long run. Cellulose dosen't go off like enamels, it will last for years even after being opened and resealed.
After much prodding from Warren I'm trying cellulose although I've used Express Paints, http://www.express-paints.co.uk/mixed-cellulose-colour/ because I could order it in 100ml bottles. Half a litre seems a lot paint for 2mm! I submitted the online form with a list of RAL and BS codes and the delivery was very prompt. I have seen mention that the smaller bottles can have a wider variation in colour because of the small quantities used but I don't think this will be a problem - maybe even more authentic!!
Mick
Richard, I picked up a SPROG yesterday from Sudbury, reasonably priced as well, also some printable decal paper so that'll be on going in the back ground as well. Next on the agenda is airbrush and compressor research and purchase :thumbs:. Once I get an airbrush set up I can tweak the colours to make more faded versions in due course.
I've also just ordered three cans from Doncaster autopaints, a blue and two shades of a darker yellow, after much web browsing it looks like no one really knows the exact colour of the YN3 nose yellow, which is actually classed as gold by CSX it would appear. Once I'm happy with the final colour I then need to match it to the decal sheet I'm doing. It isn't so important to get the exact yellow but it's more important that the logo and road numbers match the colour.
Mick
This is where we got our paint from
http://www.lewentltd.co.uk/
Cheers, sites bookmarked :thumbs:
Ever onward, the new cans arrived today, so straight out after work for a quick colour test.
The lighter yellow wasn't much better than all the others to be honest, but sprays just lovely, the colour is a good match for a fresh YN2 colour scheme.
The second can was much darker, I had thought I might even have to go for a richer colour but opted for this one and to my eyes, looks pretty spot on for the YN3 paint scheme, a much deeper richer yellow/gold colour.
Rubbish point and shoot images, struggling with the light and auto white balancing.....pretty badly!
Outside
Inside
If anything it's now a little too rich but only a smidge, it'll weather down nicely I think.
The third can was the same blue as decided on before, it appears that it's the same blue for YN2 and YN3, but can fade terribly in the YN2 scheme.
For the record so far.
YN2 scheme
RAL 5000 Blue factory fresh, faded to test later.
RAL 7004 Grey, I've not tested this yet but will once the AC60CW starts to come together.
RAL 1003 Yellow factory fresh or Rover Inca Yellow for in service and Fiat Broom Yellow for faded.
YN3 scheme
RAL 5000 Blue factory fresh.
RAL 1007 Yellow Factory fresh and you could probably get away with RAL 1003 as faded
Both YN3 colours seem to hold their tone rather well in service but as previously discussed, the blue changes dramatically depending on the climatic environment it's viewed in.
RAL 1007 is also the closest I've found to factory fresh Union Pacific but it'd need a bit more yellow for casual wear and I'd probably use Rover Inca Yellow for a faded unit.
Onward!
Pugsley
Have you thought of trying BR Blue (or one of the car colour equivalents) for the YN3 scheme?
I had, but haven't explored it any further at the moment.
Addendum, a quick check shows BS381C 108 as BR blue
https://www.e-paint.co.uk/uk_organisations.asp?cOrg=BR
Cross referencing the RGB with RAL comes up with RAL 5000, having said that, so does BS381C 104
All three seem very close in their RGB values.
Big Train James
It had been mentioned earlier in the thread about the dearth of O scale CSX decals, and in particular for the Yn3 scheme. Microscale does make a Yn3 decal set, and even at one time made it in O scale.
Microscale 48-744
Of course Microscale has long since stopped producing O scale decals. I took a look around the web and in particular the two hobby shops I might expect to have O scale decals in stock. I could only find the Microscale Yn2 scheme decals. So this post is only slightly useful in that one could keep an eye on ebay and so on to try and score a set of the Yn3 scheme. Only relevant if you weren't yet aware of this set.
Jim
Edit: Oh by the way, you could always commission Microscale for a run of the O scale decals. They clearly have the artwork. All you need to do is find a willing group to take the rest of the 250 minimum run that you don't need off your hands.:oops:
Microscale 48-744
Jim
James,
Yes YN3 scheme is very hard to come by, as are many other O scale decals it would seem, I have just managed to get a YN2 set off Ebay so it will be good to compare the blue they have used with the colour I've finally arrived at, hopefully they should be pretty close.
I've also got some blank decal paper and now that I have a RGB for the nose will work up some YN3, YN2b and boxcar artwork and simply print my own, they may not be perfect but if the colours are right/close and the artwork sized correctly, I can send the master file off to a professional decal printer and have a few sheets run off.
I've tried some quick tests at work on our laser printer and the trick seems to be not to draw at 1:1 size, this doesn't give a nice smooth line when printed, it appears to be better when drawing at 4x scale and then letting the printer compress to suit an A4 sheet, the printer appears better at compressing and making better lines than a 1:1 print, lot of water to pass under that bridge as yet.
CSX use Lubalin Graph Bold but with slightly modified serifs, you can get Lubalin Graph Bold for free off the web and it's not hard in PSP to start to edit the serifs and fatten up the boarder around the YN2b scheme. Of course the final article will be on a white back ground which prints as clear, the current ones are simply there to give me a colour reference. I'll also add all the little warning decals that CSX plaster over their locos, hopefully letting the printer do the compressing will still make them virtually legible.
Bit rough and ready but for trials of colour, line thickness and spacing etc it'll do, the YN2b X has its border thickened but might need another pass and the serfis on all the letters need looking at.
Little bit of an update, managed to find some time for some colour test prints.
Logo sizing and colour
Height is correct at 40", length, best guess from comparing real photos and position on doors, hinges, latches etc. The blue colours are totally wrong when compared to the spray, so a sample sheet was printed.
One or two are a close match, being as blue doesn't go on blue you won't ever see direct adjoining colours so close...should be good enough.
I though I had the yellow down just right as well
Clearly I do not! Strange thing is, under lighting inside the yellow is spot on and the blue a little dark, I'm not sure how the decal paper is going to react to colours, being a sealed surface I'm hoping it'll have a more consistent and deeper colour depth, clearly normal paper absorbs some of the ink and gives it a slight blotchy look or washed out look.
Pugsley
Are you using an inkjet, or a laser printer? A laser printer should be more consistent across normal and the decal paper, as it doesn't get absorbed by either.
Laser, but as you can see on the blue, it isn't a consistent colour and has little waves or blotches in it, but then the decals are going to be considerably smaller and the effect less noticeable...I hope :cool:
Pugsley
I'm surprised by that, laser is usually very consistent, although I must admit I don't think I've ever printed a single colour area quite that large before.
The yellow is much more consistent and there's a whole range of print options to choose from which might increase the colour density so it might not all be bad news, it could just be the paper which is typical office bare bones minimum grade, I have some spare photographic high gloss paper I could perhaps test it on and see if that makes a difference.
To be fair, the CSX logo is the largest decal on any of their locos which is significantly smaller than half an A4 sheet and the effect much less pronounced.
Well I thought I'd try some of this 'box opening' lark everyone keeps going on about :cool:
Not only do you get one big box to open, you get four smaller ones inside....result :)
Nuff said :thumbs:
Never had a Weaver across my desk, simply excellent upper works, totally awful running gear, I knew they were three rail and they'd be course scale, but my Pizza cutter is more fine scale than these :eek:
The bulk head flat also needs new wheels, in fact all my US stock needs new wheels, all seem to be in the region of 17.5mm dia and 45.6mm across pin point axles so I'll have to surf the web for suitable metal replacements, Peartree, Slaters ??. The Weaver ones might be a bit more problematical as they have great big cast steel bogies, I may just drop these out and stuff in some Atlas ones off the 40' box cars I have in the loft, I'm modelling too modern for 40' box cars so they're sat there in fallen flag liveries awaiting a decision, I could flog them on E bay and convert the funds to more modern ones, use the bogies to replace the Weaver ones and put the bodies on the ground as storage units in some industrial scene, or, repaint into a more modern fictional scheme and apply rule #1 and use them as consist fillers or siding fillers.
There 'was' four of these high cubes but some goit whipped one from under my nose over night....Jordan? So I only ended up with three, and no, I didn't pay list price, it's amazing what a polite phone call and offer of a bulk buy will get you in a price reduction :D
Still need a few Waffle side (I hesitated at Telford last year and Jordan snaffled up the only decent one waffle side I've ever seen, mind it was graffitied and I'm not a fan of that, prototypical or not) and some centre beam cars and I'm thinking a rotary dumper with some high cube wood chip gondolas to unload might be a nice set scene. Some tank cars might be nice, there's a nice little industry at Taft that has a couple of small (by US standards) tank cars a week, it contains concentrate corn flower syrup which the Americans use extensively in their products, mainly sweets and soft drinks, the little industry basically decants the syrup and dilutes it into a ready liquid for soda drinks, the bottles of dilute going out by road to other industries that add the flavouring and bottling/canning.
Another nice industry is a small wood unit, imports include wood chip and logs plus the odd tank car with chemicals to clean/treat the wood as well as adhesives, outgoing is box car pallet wood products or big centre beam wagons with sheets of wood. One unit and at least five different types of rail car.
If the weathers nice at the weekend I'll grab all the stock out and give it a once over and snap a few photos :thumbs: Also hope to flesh a bit more of the layout plan in the near future...but the W1 etches must come first ;)
