The Dornoch branch had a resident ex-LNER Toad B brake van from Nationalisation until closure. When the Parkside 7mm scale Toad E kit came out I purchased one and put the body together. I didn't get around to buying a Toad B kit before Peco took over and have been hesitating since due to the reduced ease of buying from outside the UK and the lack of ability to have the wheels changed to S7. It struck me yesterday that I am probably better starting with a Toad E kit anyway as the Dornoch van was one of the narrow plank version rather than the wide plank as modelled by Parkside. The narrow plank Toad B looks just like a Toad E with different duckets, some even had the same short angle iron end braces. I am not an expert on LNER brake vans so if anyone knows of any significant differences which would mess up the conversion let me know.
This is what I plan to end up with -
Does anyone know this vans number?
And this is where the kit is at present -
A fair bit more difficult to modify the sides with the kit assembled but at least I hadn't added any detail and the roof is loose. I have drawn the timber duckets for the Toad B and will make them from plastikard. The end braces will also be changed to the larger timber version, and the side planks should stop at a horizontal strip across the bottom. The van at Dornoch seems to have pre-RCH buffers which is a bit annoying, most had RCH buffers. It may have to stay as it is as once the ABS plastic buffer guides are glued in they aren't going anywhere. I think the conversion will be a better outcome than trying to modify the wide plank Toad B kit to a narrow plank version.
There is a plan for the Toad E duckets.
