7mm Stroudley Park
A Milestone Day
SouthernFan Ian
Today was the day I erected Stroudley Park for the first time. My wife was out for a Christmas Lunch so took over the consevatory for Stroudley Park. It’s quite surprising how much space a small 0 Gauge layout occupies in what I thought was a large space. Here’s a few general images. I just couldn’t resist ‘testing’ some locomotives!!!
IMG_9323.jpegIMG_9318.jpegIMG_9313.jpegIMG_9307.jpegIMG_9286.jpegIMG_9179.jpegIMG_9180.jpegIMG_9285.jpeg
There’s still much more to do but it was a very enjoyable day. I think a celebratory glass of Auchentoshan is called for.
Regards,
Ian
spikey faz
View attachment 252944View attachment 252945View attachment 252946View attachment 252947View attachment 252948View attachment 252949View attachment 252951View attachment 252953
Regards,
Ian
Love the Bulleid West Country. Do you mind me asking which kit it is based on?
SouthernFan Ian
Hello Mike,
It’s actually a Meteor Models kit. It took me a long time to build as I decided to scratch build several components as I wasn’t happy with some of them. I also added sprung Hornblocks as well. Most of the cab backhead is scratch build. I would have preferred a Finney kit but Meteor was the cheaper option.
Regards,
Ian
Some joker thought it would be funny to attach a bogie brake van to the morning milk train.
With much cursing, wheel spinning and engine revving, the full milk tanks were positioned for emptying. At least the guard was pleased, he had a smoother ride.
At least the joker used one converted from the ex-LBSC electric 'luggage/milk' driving vans.
Spring Time - Well Nearly
SouthernFan Ian
Spring time refers not to the season but spring suspension. A job I’ve been putting off for months.
The photograph shows Ruston No1 carefully pushing a Van C carrying churn traffic into the dairy and there lays the problem.
A Van C is long wheelbase and when I built it several years ago, I nievely built it without any form of suspension.
I recently discovered Connoisseur Kits retro fit spring suspension kits and this gave me the opportunity (with bated breath I might add) to carve the under frame of the van to accept spring suspension.
The kit is extremely well thought out and went together like a dream. My biggest dread was prising out the wheels to shorten the axle by removing the axle ends.
Now fitted plus a bit of 20 thou packing for free running, the end result is shown here just waiting for a bit of attention from the airbrush to blend it all together.
SouthernFan Ian
Last week, Stroudley Park was erected in the conservatory again (this is becoming habit forming). Fellow Western Thunderer Dave Bowden was there, along with two other local 0 gauge modellers with a friend from Holland.
Bill Rankin’s H Class is in the foreground and my Brighton D3 is about to depart with a Balloon push pull trailer and an arc roof lav composite. Both locos have split frames electric power collection.
The finished running in board was fitted for the first time and I am pleased with the result. My original plan was to have a proscenium arch but I felt it would be to intrusive and impede shunting operations. I rather like the openness and from a practical point of view, it holds the top edge of the backscene in line.
Regards,
Ian
Preparing a Sequence Timetable
SouthernFan Ian
I am venturing into a world I have often considered but never visited: The World of Sequence Timetable Operation.
The problem is I do not really know where to start preparing a timetable that will actually work!
All the turnouts on Stroudley Park are now numbered and the crossover at the station throat is visually identified as 4A and 4B. Plans are in hand to label each turnout control switch with N and R for normal and reverse. It is intended to incorporate this nomenclature into the timetable.
I suspect to create a proper timetable that works will take a considerable amount of time.
If any Western Thunderers use a sequence timetable, would you be willing to share your thoughts please? Thank you.
Regards,
Ian
James Spooner
Regards,
Ian
Hi Ian,
I do use a sequence on Elmham Market, but cheated as the station is based heavily on Lavenham. I obtained a copy of the working timetable for the Stour Valley lines in the early 1950s and used that as the basis. When I added Stratford St James into the equation I overlaid a service of four return push pull trains and a daily pick up goods into the existing timetable/sequence.
i think, if I were starting from scratch, I would do some research into common train frequencies for stations of the same ilk as yours. I would then factor in things like your dairy, which is going to need at least one train of tankers a day, plus probably incoming items such as coal etc and start to build a pattern. At the end of the day, the world is really your oyster; if you want to add in horse-box specials for a nearby racecourse, you can!
Nigel
Weathering Challenge New
SouthernFan Ian
For a long time, I have admired the work of our Masters of the Airbrush, especially those skilled people who weather a locomotive to a restrained ‘Used but Clean’ look.
This finish has eluded me until now. I didn’t tackle it because I felt daunted by it, until today that is. I had an afternoon to myself, the weather was good, so I sent an afternoon in my weathering studio AKA, the garage.
First up is the motive power for the Director’s Saloon, a Class I3.
My airbrush is a Devilbis Sprite of around 50 years old and still produce my desired results.
The I3 is shown below in all its used but clean glory. Quite chuffed with it really.
Regards,
Ian
SouthernFan Ian
Spurred on by the result of the Class I3 and while the weather was conducive to airbrushing, I decided to tackle my remaining pristine locomotives.
First up was my E1 number 138 resplendent in Southern goods black lined green. Although in reality the green lining was not very visible under a coat of grime, I wanted the green lining visible and here’s the result.
While the airbrush was in use I tackled the D1 256 next with just an overspray of light grime.
The Billinton D3 number 373 was given a much more subtle treatment of grimy but cared for finish as befits a passenger locomotive IMG_1528.jpeg
Finally, the K Class number 2351 got the weathering treatment. The K’s were kept reasonably clean during Southern days although they were goods locomotives. I wanted my K to portray that finish.
There’s only one loco under construction at the moment, a C2X to be finished in plain black, weathering as yet undecided.
Regards,
Ian
All looking good - just enough road dirt for daily use. When you study photos of the SR in this period, locos and passenger stock were kept clean but not highly polished. The latter appeared to be reserved for locos rostered for special duties such as Royal Trains, trains conveying foreign heads of state, inaugural trains and possibly others of a similar vein.
