Stevers
A revised 1862 First with the extra unprototypical footboard brackets at each end to keep them straight(er). Close inspection of the tumblehome will reveal the pixellated steps that Anti-Aliasing (if genuinely available on the Mono 4K) might soften. Beyond it is an 1859 Pass. Brake sporting what I understand to be a 'Nine Elms' style caboose, painted, glazed and most importantly, safely separated from the edge supports and fitted without accident. This is the version raised by 0.5mm compared with the Weddell drawings to better match photos. Happily the templates I made for the original version now fitted perfectly! The double sided tape that I used to secure template to glazing had a more sticky and less sticky side. The stickier side needs to be on the template not the glazing - don't ask me how I know! The use of a brand new Swann Morton blade being essential when attempting to cut this (or probably any) sort of 'Plastiglaze'.
The very controllable Armstrong Whitworth DE shunter will be useful to shunt all these old coaches around, so I've been amusing myself by adapting the Mercian Models running plate to accept my 3D printed body. With the body being scale and therefore smaller than the Mercian etched body with thicker walls, clearances are now quite tight. I reduced the hole in the middle by edge soldering some 2 x 2 mm brass angle to give an upstand to locate and glue the body to. I then found that the added material interfered with motor mount and pickups requiring me to provide clearance via gapping the new upstand. When offering up the body to the running plate and viewing it from the front with a critical eye, I realised that the bonnet front had been printed on the skew with a distinct curve to the prominent radiator. I've also added the rear footsteps and am working on a solution for fitting the air tank across the back that can't be in one piece due to the rear steps with that wide bottom tread trapping the tank and/or the chassis.
