I promised some shelf queen photos in my
intro and this thread seems to be an appropriate placeto stick them.
They are all 7mm.
First off is a Slaters Manning Wardle F class. Pre ordered this from the first batch, so 1986/7ish. Probably started it as soon as it arrived. Apart from the buffers, brake gear, revised suspension for the front axle she is built more or less as intended.
I suspect that a S7 conversion would involve major surgery but not impossible.
Next off is the GER 134 class, was going to be No. 135 in 1900's condition but now in line for S7 and reverse engineering to as delivered in
GREEN . The close up is a good reason for going S7!
The little Millwall tank more advanced than it looks with most of the plate work cut and awaiting lots of rivets. Some how I managed to set the frames quite wide so going S7 shouldn't involve much more than sourcing some 3'6" 11spoke drivers, re-profiled Slaters Isle of Man drivers are a possibility.
If that lot posts ok I'll do part 2.
R
