Rob Pulham
In between building the Kirk coaches I have also been assembling the other exNBR bogie CCT. This one will be finished in LNER livery for my own stock.
In NBR and LNER days the side panels were all half beaded this has been added using 0.8mm half round Plastruct strip.
Although I will be making the sole bars from plastruct strip they are too long to make it out of one length so it will need to be joined.
In order that this isn't visible on the finished model I plan to draw up and cut some 10 thou overlays. Which I plan to rivet in the same manner as the tar tank. This is in the hope that it will save me from drilling, cutting and inserting the many stubs of rod that would otherwise make up the multitude of bolt/rivet heads visible on the sole bars.
. Each tool has it's benefits depending on the material you are wanting to cut.
