Peter Cross
Quick update on the composite. It's now got two sides and two ends. Needs a good clean and tidy up. Not sure what brass it is but looks awful an hour after cleaning.
Back to size it's a millimetre under 63, 9 foot wide. Looking at the roof I need to find a way to solder it on and remove the floor. I'm sure it will be stronger and the roof will fit better.
Also checking to see how the door hinges should look.
Also in between the windows there should be a cover strip but there's an etch channel instead. Here's an experiment to try and get flat strips. 0.8 wire soldered in and filed flat. I think it is a vast improvement.
No lav vents yet need to check but sure there should be only 1 not 2.
