Snagging list stuff before I set to with lining and lettering with this loco.
First, I disassembled the thing to rewire the motor and pickups. This was to correct the polarity
, and also to incorporate a plug and socket for DCC-ifying later. I also carefully ran a big file across the chassis ends to make it a little easier to slip it in between the buffer beams.
I also rectified some sticky buffers, which now compress nicely.
The bunker ballast was extricated, after some choice words and slightly chipped paint on the rails, and made to fit into the floor better. A dollop of Copydex will hopefully prevent it rattling. Next job will be to make some kind of tray to hold the coal load. I am aware of the dangers of mixing lead and PVA, so want to avoid contact if I can.
The Modelu crew are being test fitted. I’ve not found names for them yet.
Still to do is the glazing and some detail painting and weathering in the cab.
If I feel strong enough I shall attempt lining the tanks and cab sides tomorrow.
