Well, am I glad that’s over, fellow Westerners.
I refer of course to the job of glazing; glazing the front panel of the train shed roof, to be more precise.
Actually, the fitting of the glass panels (tape cassette cartridges) went okay as per my last post, and the fitting of the exterior frames wasn’t too bad, but the glazing bars……. What an ‘orrible , ‘orrible job that was, made worse by being too impatient to send off for MEK and using some canopy glue I’ve had for some time. Tried cleaning up, but I erroneously thought I could clean up the excess hours after applying the glue. Wrong. The lumps can be disguised under the gunge intended for the glass, but talk about making difficult jobs harder.
Wouldn’t mind, but am intending to apply a thin coat of matt varnish to mist the glass before painting, but when I thought about it (later!), I could have killed two birds by using ordinary poly cement: it would have glued the bars first time every time (I had to revisit several as initially I’d been too cautious applying the glue sparingly which led to them coming loose, and in doing so, created a greater mess!), and the poly would have caused the ‘glass’ to mist evenly. Hey Ho!
I’ve exterior framed the glass panels within the A frame, front and rear, of the panel shown in the pix below, but I’ve only applied glazing bars to the front - it really strains your eyes as well as your patience.
Front:
Rear:
Not sure if you can see the glue marks, Westerners, but let me assure you they’re there
I say it’s done, but there’s still the rear panel to do, however, I’ve a cheat in mind as I’m not going through all that again - should have cheated in the first place and asked my nephew to print out the frames and the bars on his three dee printer
- but it shouldn’t be necessary with what I have in mind.
To spare you the angst of listening to me drone on, I shaln’t post up the resulting rear panel - which I’m hoping will turn out pretty much the same - but I’ll send some pictures of the architraving which will ‘adorn’ the front next time.
Apologies for the whinge.
Jonte
