7mmMick
Give it a couple of years and hopefully I'll be able to churn some decent stuff out again!
JB.
I'm sure you will pal, get the little one off to school and you'll be amazed how much free time you have again.
Mick,
Have you deliberately not fitted the additional pivot to the rear bogie (part 53) or is it an oversight? In my experience with the one I built in P4 it does help. One other thing is the side-control springs; there should be some spring steel wire in the kit which works well and it appears you're using something else? Although Martin doesn't say so, I wouldn't solder it in place either, just leave it long and splay out the ends; it gives more flexibility.
Steph
Additional pivot - I agree. The Adams Radial works very well using the MF system.
Side control springs: yes, there should be material in the kit and Martin's advice is to fix one end only and leave the other free. I can vouch for that system working well too!
Brian
I had deliberately not fitted the additional pivot, my thinking being that it wouldn't be needed in S7? If you guys recommend the alternative pivot though i'll get it fitted. How does it work? I take it the bogie pivots from the front, allowing a tighter radius to be negotiated?
I'll dig out the spring wire and get in fitted, knew I had seen some somewhere
Thank's for the heads up prior to painting
Mick
The condensing pipes, boiler feeds, handrails, whistle and safety valves are all just sat in place and will be fully fitted once painted. Likewise the rear vacuum pipe and footplate lamp irons are not fitted as this would make the bunker lining a real pain in the backside and duplex pump pipework is yet to fit as this is bare copper
"Must not start the V2's yet. Must not start the.........."
But he's far better at it than I and the Jedi master is surely Richard. Maybe it's the solder you're using, I've gone over to almost all 145 these days.
