Dikitriki
Hi,
Ken, if you look at photos of City of Birmingham in the ThinkTank - and this went straight out of service into the museum - the pipes seem to be painted black, or at least are so discoloured as to be black! Modelling the latter days of steam, my Duchess of Montrose will be in green and grimy, so no bright copper to be seen.
One of the things I like about the Duchess kit, is the way it is designed to be built in sections. This makes handling much easier, particularly when adding detail, and with a little thought, it's possible to have all the sub-units bolt together. I have been working on the cab. All the bits fit, and the only thing you need to watch is that the front of the cab exactly matches the rear of the resin firebox.
The inside of the cab is nicely detailed, and there are proper frames for the windows. The trickiest bit here is bending the etched rear part of the firebox to match the profile of the casting for the backhead. As part of the bolt together ethos, I have added a brass plate to the bottom of the cast backhead (more later) and drilled some holes in the cab floor so I can screw the backhead in after the cab has been screwed to the back of the resin firebox.
The rear of the cab bolts to the footplate, but I altered the design slightly. I reinforced the inside of the 2 tabs with milled brass angle, and soldered the bolts to the outside of the tabs. These were subsequently filed back and retapped, but it means that the cab rear can be screwed home without pulling the tabs out of shape, and will survive being removed many times.
. At least I didn't mic it to ensure it was a true cube
