Love Lane, B.R. (E) c.1956-59
They did that on Inkermann Street, the MRJ layout. I wonder where that is now?
According to a post on the Guild forum from last year.
The viaduct actually came from the MRJ sponsored diorama “Inkerman Street” which was acquired by a member of the LMS Society with a view to restoring and extending it to exhibition condition thereby raising the profile of that Society by offering a layout to Exhibition Managers. The original was set in wartime Salford and so, being a Mancunian (in exile) I was tasked with designing the extension which I did but construction stalled. The period was moved to the mid 1930s but once again I became disillusioned with lack of progress so, rather too late in the day, I have picked up work on my own layout at an age when most are looking to downsize theirs. The viaduct was only detailed on one side and was showing signs of distress so I restored where necessary and built completely new ballustrading for both sides so, until it returns to its intended layout,
So I guess it's in storage and in bits at the moment.
A bit of a shame - it did make an appearance at the NEC (and I remember seeing it - just - I was only 9 and it was very high up at the MRJ show), there. Lots of shiny LMS stuff which looked extremely incongruous on it - and very low down - at the NEC. But keeping old layouts going is always a struggle.
S-Club-7
Not too much to see at last week's meeting: more capping bricks on retaining walls (see previously), and servo adjustments in the goods yard.
Bargeboards and revised chimney pots on the ex-GER cottages. Some of the team discussing whether another cup of coffee is in order before they make a break for home.
One of the main window frames from the pub sitting on the 2nd draft of the internal staircase (much of which will eventually be hidden).
S-Club-7
Much of the same this week. More retaining wall capping bricks (see previous posts for photos) and servo adjustments (not very photogenic).
Did find one of the Goddern Arms chimney stacks and version 3 of the staircase squeezed into the interior (version 1 is behind).
And we did spend a couple of hours down at the pub having our group Xmas lunch. Hopefully some more photogenic progress next week at what will probably be our last meeting of the year.
S-Club-7
One of the six front rooms in the railway cottages. I get given funny looks if I mention skirting boards, picture rails, doorway architraves and internal doors... My excuse is that these will be positioned a couple of inches from the baseboard frontage and not far from eye level. And it is supposed to be June so the windows will be opening...
The retaining walls behind the cottages. X marks the position of the up starting signal.
Progress on the pub is mostly happening to the overlays which will be added to the carcass once the brickwork is complete. Chimney stacks (left) are part-way through being bricked and early versions of the internal stairway can be seen on the right (if a job's worth doing, it's worth doing twice).
I finally managed to sort this switch assembly; the problem was cured by replacing the insulating bushes between the stretcher bars and rails, and by relocating the servo with respect to the slider. The second photo below shows the demo piece which is how it should go together beneath the baseboard (from left to right: slider, servo, MERG CANMIO).
That's all folks...
...until next year.
Heather Kay
I’ve been thinking of the ones higher up the wall, generally used to hang pictures from. Nan's house definitely had those. Frankly, there was so much brown furniture around the rooms you couldn’t get a chair anywhere near the walls!
Dado rail at about “chair back height” or the top of half panelling.
Picture rail at about 6’6, ceiling height a good 18” to three feet higher.
other options include a plate shelf at picture rail height, the shelf had a groove or toe to stop plates sliding off.
i miss proper high ceilings, I dont miss the decorations of yesteryear!
