.......and another board has been extended by having a triangular section grafted on at the far end of what will be the goods yard and road bridge.
Should really be a Central Line electric train stabling yard
Love Lane is still considered the terminus of outer suburban London commuter services but with the main line continuing onwards to Cambridge with all the traffic that entails, express passenger, parcels, milk and goods etc.
Wow, that really has been stopped back.Love Lane has been extended and some of the old boards replaced with plywood built boards. This will enable the team to build, by far, a more prototypical ex GER goods yard which we felt Love Lane would have featured if it really had existed.
There will still be the loco servicing spur albeit in a different position and the revised track plan will create much more operational interest with a double track main line throughout the layout.
So here's a little taster, lots more work to be carried out.
Col.
.... and even flat-fronted 1935 experimental stock!Make it really interesting and turn it into a Central Line terminus similar to Epping and create a GE version of the Met/GC line. Then you can have LT 1923, 26, 27, 29, 30, 31 and 34 'Standard' and 1938 tube stock......![]()
Col.
Very exciting stuff this John and inspirational to boot! Are the track bases an intentio product and if so is the process straight forward ? It seems a real time saver ? Looking forward to seeing how it comes togetherAn extra comment about the trackwork being constructed on the curve. From the halfway point on the curve round to the storage loops is not regarded as scenic. While we constructed storage loops by soldering rail to copper clad sleepers we didn't find it any quicker than assembling chaired track on individual sleepers. For this new track we have used laser cut track bases as shown and will use chairs to hold the track. This has been inspired by Tim Humphreys' (Mudhen) new layout where he has used this process. The bases for Love Lane are cut in MDF and we have found that the chairs bond to the MDF using butanone and the bond is remarkably strong.
Home grown track bases, JBVery exciting stuff this John and inspirational to boot! Are the track bases an intentio product and if so is the process straight forward ? It seems a real time saver ? Looking forward to seeing how it comes together
@Oz7mmThere was still quite a lot of work for David (OfftheRails) to amend the Templot drawing for laser cutting.
John,Track plan print done this morning (thanks Prontaprint, great service).
Picture 5 shows the new track base for the end curves at the country end of the layout which was formerly single track. Doubling the track meant building two crossovers to gain access to any part of the storage siding. Even masochists like the Love Lane team drew the line at a curved scissors crossover.
Allen, as John says above sums it up although I will add that about the only remaining part of the original is the station section which is basically the station buildings, two platforms, and the Up and Down main.Identification please. Is Love Lane a development of the layout that was in the shop, Perfect Miniatures (Peter Hunt) in Sudbury at one time?
I know Peter has retired and moved near Banbury I think.
Allen
