Andy Ross
Hunslet Works Update.
Apologies for the lack of posts recently. There has been some activity but at a reduced rate due to ongoing issues recovering from Shingles.
I took the test track board to Narrow Gauge North at the beginning of the month and this was well received.
We are now on the last push to get the complete layout ready for York which is less than a week away.
All the wiring is (I believe) complete and there will be a final test on Tuesday.
One of the main jobs still to do was to get some sort of lighting into the Boiler shop roof.
This also means I had to sort the removable section by cutting the longitudinal beams and finding a way to secure it in place.
![IMG_2246.jpeg.6c2897de1128191a97841853c18e0580.jpg IMG_2246.jpeg.6c2897de1128191a97841853c18e0580.jpg](https://www.westernthunder.co.uk/data/attachments/212/212027-5b3ca36c55b77b96da0809b217dfdfbb.jpg)
It's been a long time since I had this much access into the main shop.
The roof lips under an angle on the wall side, and the solution on the other side is magnets.
![IMG_2248.jpeg.986dcdf110bc881be648b0e2689fce4c.jpg IMG_2248.jpeg.986dcdf110bc881be648b0e2689fce4c.jpg](https://www.westernthunder.co.uk/data/attachments/212/212028-ca335ed0c3871a7001370d91eb26ee01.jpg)
The magnets are mounted in some special sections I made on the filament printer.
In the bottom edge of the roof panel is the opposite magnets but these are behind a 2mm layer of plywood to stop them locking too tightly together.
The LED light strips are mounted on another 3d Printed section that positions them behind the top of the roof truss.
![IMG_2256.jpeg.6a920b05edc042f1c7997388e3ba402d.jpg IMG_2256.jpeg.6a920b05edc042f1c7997388e3ba402d.jpg](https://www.westernthunder.co.uk/data/attachments/212/212029-e726bc15c47413f9d2af1eb40194b1a3.jpg)
![IMG_2254.jpeg.ac360cc2631adbd73fb826617c1d348c.jpg IMG_2254.jpeg.ac360cc2631adbd73fb826617c1d348c.jpg](https://www.westernthunder.co.uk/data/attachments/212/212030-83d0af2c57c2b54522b8f22a8288f366.jpg)
From the viewing end these should not be too noticeable.
![IMG_2255.jpeg.c314864ee210513ef73a51fc0e461d83.jpg IMG_2255.jpeg.c314864ee210513ef73a51fc0e461d83.jpg](https://www.westernthunder.co.uk/data/attachments/212/212031-e8ea9c9abc006d37719042ff2168630f.jpg)
The top section will be glazed.
You will also notice the roof panels are all done with all the layers of ply for the inner structure. These take hours to cut.
I have also been fitting chips into a couple of locos and I am still on with getting the MOD loco working but more on that later.
We also realised we did not have any sort of name plate for the layout.
I mention this to Jill and when I got home form work on Friday she had come up with a design based on the Hunslet works plates. I cut some ply to mount it on and Jill used the Cricut to do the rest.
![IMG_2245.jpeg.05e78cdcb902aa69e755109c8555c9ca.jpg IMG_2245.jpeg.05e78cdcb902aa69e755109c8555c9ca.jpg](https://www.westernthunder.co.uk/data/attachments/212/212032-679de8d48b008f2522a4eb313761c0a2.jpg)
If you come to York over Easter please say hello. We will be on the first floor mezzanine with the demonstrators as we are still very much a work in progress.
Hope to see you there.
Andy
Andy
