Edinburgh Princes St in EM
Stephen Freeman
Having built a few of the kits, I think I have a few spare plinths if needed. The fun will start if you want to make the signals fully operational as most of the operating bits were usually to be found below walkway level. At least the hole in the wall may prove handy even if not entirely prototypical.
Ian N
Hi Stephen
Thanks for the offer, but I'm 99% certain that I'm happy with the appearance of the partially buried effect even while it's at the unfinished stage.
It was the underside of Tony Gee's gantry that he had on a demo table at last years ExpoEM Summer that provided the motivation to get this started. It provided a plan B if the hole-in-the-wall approach didn't work out. As it is, there are timber supports under the leg, so this one is back to Plan A.
The station gantry is probably next, but is quite different in appearance with the dolls and walkways mounted outside the gantry As partially evidenced in these images - Station Gantry 1 and Station gantry 2 . Much more modelling involved, and I think I've worked out how to do it while keeping the character. The usual dearth of good quality photos of the bits you really want to see doesn't help though
Ian N
Time has recently been spent building signal ladders. I don't mind the soldering of individual rungs, although discovering you've included more rungs than are actually needed is a learning curve.
It's the amount of time to clean up everything the cutters don't leave flush. To save time ( sanity already gone...) I'm going to try 0.3mm wire soldered to the outside edges of MSE ladders next. Construction of the dolls has been completed, the vertical operating linkage installed, the dolls soldered into the span and the first plank of the remaining walkway added.
It's planned to use 1mm x 2mm magnets superglued inside 1.1mm inside diameter tube which have been previously soldered to the operating wire as a way of making the gantry detachable from the servo's. This enables the gantry to be removable from the layout for transport. These magnets have little attractive force end to end, and negligible force transversal. However there will be a degree of separation between " connections " to ensure complete separation.
I was going to say here's one I made earlier.... this is the departure & call on signal for platforms 2 & 3. Turns out it was started quite a few years ago! The holes in the lamp were for the inclusion of LED lighting. Suffice to say, it seemed a good idea at the time!
Ian N
And this is where progress stalled on the departure signals for platforms 5 & 6 due to problems getting the second leg attached. In the following 11 years, the deck has developed a slight bow, which can hopefully be addressed after temporarily removing the handrail and replacing it so that it doesn't jar to my eye as much. It's not too far from finished, or so I thought. Definitely less than building the gantry!
As seen from the other side, maybe slightly more work than I first thought
Platform 5&6 departure signals
Ian N
In what is likely to be one of the last photos of the layout in the garage, fingers crossed it'll make its way to the ScRSG club rooms this afternoon where it'll be reerected in due course in it's entirety. Having been untouched for a few years, there are bits needing attention. The steel rail tarnished where left uncovered, but a surface layer of rust where things were placed on the track, restricting airflow.IMG_7565.jpeg
Ian N
Four and a half months later, the reassembly continues. Only being able to attend the club rooms once a fortnight slows progress on the major work, and a decent summer and other activities have affected home modelling. On the bright side, the dark evenings have returned, and the dogs are now happy to chill, instead of wanting to play, after their walks.
Although progress has been slow, important steps forward have been completed. The original Garage legs for the station boards where one end was against a wall to prevent movement
have been replaced with something more substantiaL The original legs will probably be reused to create a frame for the control panel to sit on. Two boards now fit completely on the new table frame and the other two rest on the frame with plug in legs at the outer edges.
The new legs use discontinued IVAR preassembled 220cm legs cut as required. At the price my local Swedish Emporium was selling them at to clear, it was cheaper than buying the wood.
Finally, a view that wasn't possible in the garage as it was always against a wall. Some of the minor damage is just visible
Now I have easy access to this end, the missing lengths of platform roads, and the platform itself can be made. The platform surfaces, three missing bits of platform and the structures from these boards are still to make the journey through.
Ian N
My iPad has just flagged this as a memory from 12yrs ago!
Little does it know how much other work has progressed, or not, in the interim.
This was the layout's original location in the garage backed against a wall, before it was decided to extend beyond the Morrison St bridge In the background.
This is approximately 9 feet long, about the time it was discovered it was difficult to get more than four 60+year old modellers along its frontage! The buildings next to the bridge were subsequently discovered to be out of proportion vertically and have since been rebuilt.
John Bardwell
New Member
I had the opportunity to visit the ScRSG clubrooms last night (with the West Scotland 4mm Group) and was very taken with the work done thus far on Princes Street and the enormity of the tasks yet to come. I'll be following this closely (and hopefully coming up to the Bus Depot again!). Super stuff!
Ian N
At long last, and arguably well overdue, the paint factory has finally got windows.
in hindsight, it might have been easier to attach them before internal bracing was fitted, or alternatively have wider strips for gluing to the superstructure. Having some form of alignment guide to make consistency easier might have helped too. It's not apparent, but there's no "glazing" behind the window frames, so as this is a background building, I might leave it like that.
I must do something about the roof though!
I've also been working on windows for the Morrison St/Gardners Crescent cluster of buildings where the test prints have been checked for size and the tenement where the windows have been made and are waiting to be glued in
Ian N
A long time ago in a different forum, when Princes Street was still pretty embryonic, I posted my first interpretation of the carriage cleaning platforms. IMG_1524.jpeg
Construction was out of Evergreen Plastic, with a single photo for inspiration. It looked not too bad until better research photos became available, at which point it started to look "clunky"
Plan B, after the purchase of a Silhouette Cameo was to use that to cut the legs, then laminate the layers together
The rotating blade and the plastic I used seemed not to agree. The sides weren't as symmetrical as I would have preferred. The hole, for the same reasons didn't have right angle corners, and it took months for the solvent to evaporate and the plastic to re harden in an unheated garage. A start was made to tidy them up, but they never received the deck and the scenic surface was never cut to accommodate them.
At Model Rail Scotland, I noticed one of the traders had resin printed a "cleaning gantry". Food for thought.......
IMG_8184.jpegThe leg, the underside of the deck showing the locating strips for the legs and the 2 in 1 alignment Jig. The jig was accidentally made too thick, restricting the cutting ability of a knife blade. The wider slots are for the walkway legs opposite the signal box which provide safe access over some of the point rodding runs
And finally, all glued together, imbedded in the same underlay used on the layout.
2.4 metres to go!
Ian N
A significant milestone for Princes St was reached yesterday. For the very first time, the six main scenic boards were assembled together, so the opportunity was taken to place most of the structures, bar the few still in the garage, as an indication of what's still outstanding work. It would have been amiss not to take photos......
Most of the scenic section. There's roughly another 10" at the right hand side. The scenic shelf and buildings for the SSEB complex are stored below the layout awaiting completion. A tin of black paint fo do/redo the facia wouldn't go wrong either!
Morrison St bridge in the middle distance, Grove St bridge on the horizon, where the fiddle yard will start. Hopefully, the three fiddle yard frames will be added in a fortnight.
And the paint factory finally has its extraction fan.
Ian N
And some taken by Davy Scott. Used with his permission.
Some damage still to be repaired
From above Grove St bridge towards the station. Different manufacturers styrene sheet yellows at different rates, and having tenement windows dissected by the baseboard front should have been noticed at the time!
The climb out of the station
Ian N
For the carriage cleaning platforms, I decided to remove a channel from the layout track underlay to the width of the post spacing then make a notched insert to go between the posts so the posts and insert could be glued in together. This seemed easier than trying to cut hundreds of individual post holes on the layout.
In general, it was, however the dense foam seemed to dull knife blades very quickly which results in the blade pulling the foam as it cut. At the moment it's still to be glued in. The difference between unballasted foam and the rest of the layout can be quite noticeable depending on the light, but that's easily fixedIMG_3816.jpegIMG_3819.jpegMust fix the point blade an frog in front of the signal box.
Meanwhile, under the baseboards, work continues installing retainers to prevent the legs moving.
Ian N
The residential buildings have been sprayed in a dark grey primer before the windows get added. It's almost passable for the soot colour of Edinburgh in the 50s -60s.IMG_3845.jpeg
The tenement has since had its windows added but not yet painted, and still awaits creation of the end walls, roof and other bits of character.
Unlike the other buildings where the stonework was scribed first, it is being scribed after priming in an attempt to better capture the impression of the mortar courses and the use of cheaper/smaller/lower quality stone. It's the kind of job where even a spare 5 minutes makes a difference.Early attempts to make the mortar courses less regular are beginning to show promise. I had tried watercolour pencils to draw the mortar, but couldn't get the effect I hoped for.
And here's the WJV Anderson photo of the location 78xxx Class 2 2-6-0 | 78046 1962c Edinburgh Princes Street
Ian N
The frontage of 1-3 Gardners Crescent is progressing. The silhouette cut windows have been superseded by 3d printed versions.
Life would have been so much easier attaching windows before adding internal bracing to the wall. With the exception of the tenement, all the other buildings are preassembled, waiting for windows. That's going to be interesting! Possibly not too much of an issue for small buildings, but as they get larger.....
The other important lesson, for when I do the imposing building behind Larbert station for the club, is to mark the inside of the walls with as many alignment lines as required to reduce the need to rotate the model to check correct alignment of the window in its location while the superglue/solvent goes off.
In hindsight, the two right hand ground floor window frames are too low - the curved frame doesn't follow the arched stonework as well as the others. Rats!
MacDuff999
New Member
Excellent work in all areas Ian. My memory of the detail of the surrounding area is somewhat vague, I must say though, after having left Edinburgh more than 50 years ago. A 'definite 'magnum opus' of the scale modelling kind. I look forward to further developments, and one day, the appearance of a train or two? Congratulations, it's a fabulous project, and a station I remember well.
Ian Ogden.
