Hi,
I have to say I'd be lost without my microflame. The whitemetal fittings on the crab boiler were attached with it. I also dismantled Scanlon's 76000 firebox which meant taking the spigoted lost wax brass castings off a thin white-metal firebox. That was quite nerve-wracking as I wanted to reuse the firebox.
I shall do some videos on how I use the microflame as and when I have to use it next. There are some key characteristics for me when looking at microflames. Genuine one-handed use which means auto ignition, adjustable flame, visible gas reservoir, pen-type rather than upright. I use a Nimrod Solderpro120 and would replace it like for like if it failed.
Yesterday I fitted the exhaust steam injector, though not yet the large pipe and grease separater. That was enough as there is constant checking of bends and levels for fit. It didn't help that I discovered the rear of the chassis is the wrong shape, but it's too late for me to do anything about that, and it's not really noticeable. It just meant that a couple of pipe runs were slightly out. But hey, you wouldn't have noticed if I hadn't told you.
Both ejectors have been clipped to the steps so everything is very solid
It's getting pretty crowded under there!
Got to remember to replace the rear crankpin nuts
There's a bit of filling needed on the live steam injector arising from switching the overflow pipe.
I shall have to locate my stock of grease separaters before I can do more, so it's on to the cab and the AWS bits. More poring over pictures.
