Nice track work Howard your explanation was just what I was looking for. So for a 1:6 you would bend the ends of the rail to an angle of 4.75 degrees if I am correct. I will laser cut some angle jigs for this purpose. Do you silver solder the joint?
Thomas
Thank you for the kind words.
Don't over think it!! You will (of course) be building your track on a template - hopefully created using Martin's excellent Templot! And I find that the template provides a sufficient visual guide for the angle.
The big thing to me (and I always say this whenever I demonstrate trackbuilding) - this is a skill rather than a theorectical excercise and skill ONLY comes with practice. So pick up a file and make a few hundred vees. Rail is very cheap after all! After you have made (and thrown away) a few dozen, you will get pretty good at the job!
If you find the use of a jig helps, then go ahead and use one. BUT if your track has 'flowing curves' you will have lots of irregular vees which the jigs do not cater for. And in the time it takes for your jig to come through the post, you can have made enough to acquire the skill not to need one!
I have silver soldered vees in the past - it has the advantage that you can then soft-solder the vee to the remainer of the crossing assembly without fear of melt-down, but I do not find it in any way essential. So if you already have the skill and tools for that then fine, but don't let the lack of those things stop you having a go at it. Maybe if you are making track for your guage 3 Duchess to traverse at 100mph ...
Don't want to put you off here, but I have to say that the switch blades are MUCH harder than the vees...
Hope you will report your progress!
Good Luck,
Howard
