john lewsey
Hi Phil did you get my pm
Hi BT4
Can I be rude and ask how much they cost? - they look very nice and a nice storage solution too (there are others I am considering too)
Kind regards,
CME![]()
I'm not entirely sure how to wall mount these as the Heljan loco's are fairly heavy.
Your not kidding, nearly pulled my arm out of its socket when I tried to pick it up LOL
If your going into stud walling then I'd seriously recommend you find one of the wooden support beams for the stud work behind to secure too, I'd wager a hefty amount that no cavity fixing will hold two of those with Heljan locos in.
For solid walls then brown plugs with some 70mm number 10's should suffice, two in the top box and two in the bottom, or, some good quality shelf angles underneath the boxes.
I'm worried the bottoms will fall out.![]()
Let me know which way you are heading on hols then I can go in the opposite direction and I wont get stuck behind you in traffic and thus get delayed on my way to the B&B/holiday cottage
Which is rather in line with views expressed by Clarkson...... the traffic seemed to be behind us.
when I was driving for a living
.............only joking Phil.
Just noticed the window is not quite right at the top. Will need a slight amendment tomorrow before I send off to be cut.![]()
