david bigcheeseplant
[/ATTACH]
I have been designing and laser cutting the three main station building for our clubs P4 model of Aylesbury.
Each wall is made from two layers of 1.5mm Rowmark these are aligned using cocktail sticks through holes. The inner layer of each wall has larger apertures for the window frames and doors that can be painted and just dropped in later, including .5mm Perspex used for the glass
I have been designing and laser cutting the three main station building for our clubs P4 model of Aylesbury.Each wall is made from two layers of 1.5mm Rowmark these are aligned using cocktail sticks through holes. The inner layer of each wall has larger apertures for the window frames and doors that can be painted and just dropped in later, including .5mm Perspex used for the glass
