quick check here as I have never done this before
Will I be ok collecting juice through the gearbox and its bearing? you can see my problem here. I will make the split under the plastic delrin gear, I just eant to make sure im not stiring up problems collecting through the gearbox which will make the motor case live
Cynric,
I don't like that idea much. It's a shame you haven't got another convenient bearing in the frame, but at least you'd be able to get 10 wheel pick up, if not 12. You can still usefully pick up from the frame bearing opposite the gearbox.
There are a couple of concerns, first up is the general load on the gearbox bearings; which is probably going to be the most highly-loaded set of bearings in your chassis. And then there's the problem that should the pickup bearing have intermittent contact you'd risk passing current across the even-more highly loaded gears or motor bearings. And this really is a bad idea - DCC or not.
If you think about it, the American system gives you a live gearbox every time. I have not had any problems and invariably make the chassis live to one side or the other.
Naw - generally it doesn't, Richard, unless you have the pick up wire actually atteched to the gearbox or motor casing. It's much more normal (and effective) to pick up from the frame. In this situation the gearbox is certainly at the same potential, but doesn't actually have any current passing through it.
As these are ABC units then there is one caution. Brian C has informed me that using spilt axles for those axles which run in ball races is a no-no, any sparks between the balls and the races will lead to rapid breakdown of the case-hardening and hence pitting.
regards, Graham
Which, as a general case is true and with the higher voltage, current and the fact it's effectively AC is one reason why I consider ball races, live axles and DCC to be a particularly bad combination. Even with good old analogue it could be a problem, but most who try it seem to get away with it...
Steph
