Metropolitan Class G
She runs fine and doesn't look too bad pulling a few Dreadnaughts.....
Now need the Rothschild saloon and a Pullman car. :)
Jarmstro
I do indeed. But first up I need a camelback and a Class C to complete my collection..... Not too bothered about the C though. Camelback should be possible if I can tolerate another 3D print. The C was was basically an SER Q and I believe a white metal kit was available but the chances of getting hold of one is probably zero. However, would a Rapido E chassis fit in a 3D print of a C if I could bear the sacrificial cost?? Oh, and my Class A is open cab. I'd like a later closed cab one. K's used to do a kit. But I don't think there are any left unbuilt.
In some respects I'm surprised there isn't a decent Met A class 4-4-0T kit produced/available both in 4mm and 7mm scale as they were not exclusive to the Met and District railways. Other companies using them were the LSWR, LNWR and Midland, along some of the Met tanks being sold to other companies after withdrawal.
There is a Met C/SER Q kit available in 7mm scale from SER kits.
One starting point for a Met C would be a SECR H. It would give you the chassis but the biggest issue would be the boiler pitch. It would take a lot of work to build a C/Q from the H but it does give you the tank and bunker flares. It all depends upon how much you want to chop the H body around.
There is 4mm version from Cults3D.com as a downloadable file for printing which may be adapted to fit the H chassis Metropolitan Railway C class 0-4-4T loco 1/76 scale
Wills used to produce a 4mm H class whitemetal body and nickel silver chassis kit. In reality the SECR H was a direct descendant of the LCDR R and R1 0-4-4T classes rather than the SER/SECR Q and SECR Q1 0-4-4T.
My dad back in the 1960s converted the Hornby Dublo R1 0-6-0T into a SECR (ex SER) Q 0-4-4T - nearly but not quite Metropolitan.
Jarmstro
How about a SECR H class for the chassis - may be a cheaper option.
I've already got the 3D print files for the Camelback and C. I need to find a firm who can print them to a far higher quality than the firm who printed my G. I'll start with the Camelback and have a Tenshenco powered bogie on order which may be the best option. For the C I have a couple of Rapido E's so can try the chassis in the print to see if the can be made to fit to start with.
With regard to the Metro-Cammel locos I note that most models of these locos have disc wheels but I am pretty sure that they were spoked. So spoked it for me unless I learn differently. Bogies are coming from Japan with delivery estimate end of July but whether they ever actually arrive I somewhat doubt.
