Traction Engines (and the like...)
I imagine the Long Shop Museum shop would in fact be the ideal place to acquire such information - a book at the appropriate techy level!
RichardG
Yes . . a Shire book entitled "Traction Engines" looks just right, and the shop at the museum is sending me a copy by mail order :)
AndyB
I wonder, is there a "beginners guide to traction engines" to be had? I am thinking of a book rather than a web site. There are all these beautiful photographs but I want to understand what I am looking at.
For example, why are engines a mix of left- and right-hand drive? If an engine had room to carry only one person, could they manage the engine alone or did a mate travel separately? How small could an engine be (a working engine not a model)? Why were some flywheels spoked and some solid?
I think you'll need a variety of books to cover such a range of questions. I would say there are 4 main categories: There are a lot of general 'picture books' around, which generally don't get too technical. Then there are works on the various makers - Burrell, Fowler, Garrett, etc - get to lots of technical detail, but don't talk about operation much. A third set are the more biographical ones, which do talk more about how the engines were used, crewed, etc. Finally there are some works on specific types of engines such as waggons (overtype and undertype, tractors, etc).
Will try to answer further later. Have a meeting to get to now....
Andy
Tim Watson
I would strongly recommend Anthony Coulls (NRM), book:
Traction engines fall into many types and sizes.
Traction engines as such are generally agricultural / rural usage. Primarily used for threshing. By far the simplest form. Usually single cylinder, spoked flywheel, driver on man stand, steersmen on the left. They come in a range of sizes but not massive: 5’8” hind wheel. Some would have a 1/2 - 3/4 roof.
Road locomotives are much taller and bigger, built for moving heavy loads (boilers, transformers) on main roads at speed. Nearly always two cylinder, solid flywheel (so as not to frighten horses) and belly tank. 1/2 cab: 6’-7’ hind wheel. Driver on man stand steersman on the left.
Tractors are a very small sized road loco designed for short-haul operation and one man operation: 3/4 roof. They can be 3/4 size of a RL and are fast & nippy. Solid flywheel with LH drive & belly tank. Could be used on agricultural work. 5’ hind wheel.
Showman’s Road Locos are an extended road loco carrying a dynamo at the front and a full length roof. Used for transporting fairs and generating for rides. Very decorative. 6-7’ hind wheels
Ploughing engines are unique to ground cultivation with a horizontal wire drum under the very long boiler, mostly two cylinder. Built as pairs, would haul cultivator across field by cable and then tow between farms. Dished spoked flywheel. Steersmen on left. 5’9” hind wheels maybe bigger.
Steam rollers are slow moving engines with front end rolls, belly tanks, smooth wheels, plain flywheel. They would normally have RH steersman, often being single - manned. 5’-5’9” hind wheels. They come in a whole range of sizes. Single cylinder possibly more common, often with a 3/4 roof.
Finally, steam wagons are completely different genre.
Hope that helps.
Tim
RichardG
Steersman on left can see the edge of the road which is very important. Driver fires and handles the regulator and reverser.
Well this is good to know, because my Fowler engine I have modified to become a wagon load has the steering wheel on the right. Clearly it is for export, which is what I want it to be.
I have since discovered the web site of the Road Locomotive Society. They publish books of photos and I will try one of these. I have done dozens of searches online, and suddenly their site popped up all out of the blue.
Giles
Spoked flywheels strangely give a better 'flywheel effect' than a solid flywheel - hence their use on agricultural machines, whose primary purpose is usually to drive other machines such as threshing machines and bailers which require a constant speed (they are usually fitted with governors as well). Conversely at the other end of the scale, Road rollers need to reverse quite smartly, and too much momentum on the flywheel would be problematic - hence solid flywheels, not too large.
Flywheels intended to drive machinery are always crowned in section, not flat. This keeps the belt on, which would otherwise work off a flat flywheel very quickly.
And then one can get into differentials!
John Palmer
The Wallis 'Advance' design is optimised for tarmac rolling, where there is a risk of the roller sinking into the soft tarmac if it remains stationary. The 'Advance' is a two-cylinder machine with no flywheel to impart continuing momentum when the throttle is closed. So, when tarmac rolling, you close the throttle and let the engine drift at the end of its run. As you approach a standstill, you shift the reverser to the opposite end of its quadrant then re-open the throttle. The effect is that the engine slows to a halt and immediately sets off in the opposite direction of travel without pause and at no time remains stationary on the soft surface.
RichardG
Fowler 12 ton single cylinder roller No.7446 of 1895
And yet, Fowler used a spoked flywheel (although it looks like a very lightweight one) on their roller of 1895.
I can see, if I am going to put a traction engine on my layout and avoid raising knowedgeable eyebrows, I need to choose the right sort of traction engine for the task in hand, or at least choose a suitable task for a model I might buy. Fortunately Corgi do a Garrett 4CD, which was England’s most popular tractor in the early 20th century. Corgi claim this to be 1:50 scale, but it measures up around 1:47. So a bit undersize for 7mm scale, but not drastically so.
Example 4CD: Garrett Steam Tractors – The Long Shop Museum
Dave F.
The Aveling roller I usually worked on had the steersman on the left and as has been said you can see the edge of the road but I once steered an engine through Glasgow for an open day standing on the right and had to be reminded I was a good bit away from the kerb but at least you didn't get so spotted with oil from a flywheel....
Dave F.
alastairq
As a one-time military driver instructor, one of the vehicles I ran courses for was left hand drive...and the driver's seat [and cab, of course] was quite a long way off the ground.
Bearing in mind, the 'students' were , at that point, still novice drivers..even if they did hold C+ E....and I noticed how they tended to wander across the 'centre line' of roads they drove on...think themselves to be 'too near the kerb!'
As an instructor, sat in the right side seat, finding oneself heading straight towards oncoming arics and things certainly focussed one's attention..
With the student driver looking blithely relaxed..
It's an 'optical' thing....the higher up one's eyes are, when sat on the left....the more one's brain tells one that 'we're too near the kerb...
Odd that the same students had no issues driving other, RHD, waggons...
RichardG
The r/c install in the 1:43 engine looks way beyond me, but I built this one at school! This was during my A-levels, 1978 to 1980. I packed the sand around the patterns for the wheels, made the moulds and poured the aluminium. You can see flaws in the wheels but we had to accept them for lack of time. The safety valve and the drive band are Mamod, everything else is from scratch. The boiler is copper, many decades have passed since the machine was steamed but I expect it still works. The paint is cellulose, this was before we had acrylic paints.
Back in the days when we did metalworking and the pupils were allowed to find out what happens when a drill press catches when trying to drill a 1/2" hole in a strip of steel!!
Is the smokebox and chimney a single piece casting as well?
RichardG
Yes the smokebox and chimney are in one piece. The pattern was made out of wood. The smokebox is solid, and the brass csk screw is holding it onto the front of the boiler. I remember the immense satisfaction of seeing my fresh casting, followed by the trepidation in drilling the hole most of the way down the chimney to let the steam out. The casting kept its rough sand finish, you can see where I dressed it to remove the worst of the mould joint line.
This model was the practical part of the GCSE A level 'Engineering Workshop Theory and Practice', done on Wednesday afternoons as an alternative to "sport". I was not allowed to do the A level because it clashed with Physics in the timetable, and I needed the Physics but merely wanted the metalwork. This was probably the Oxford board, I say this because the O level was. I have always been a rather slow worker. The drawings included a canopy and I missed this out completely because I ran out of time. I suspect I wasn't the first nor the last.
