A day off work on a rainy day meant there was nothing else to be done than finish the LEWIS wagon!
I started with the smaller lettering on the side posted previously:
(It is worth noting that I have not currently been able to source anything suitable for the "empty to..." message to the left of 'No.' so unless I go for a Powsides transfer and cut out the corner I require, this will be how the wagon remains for now).
Then it was on to the other side:
This side has subtle differences to the opposite; first of all, the L being shifted right by the corner bracket has meant that the E has to overlap the bracing next to the side door. This is backed up by other photos I've found of LEWIS wagons. Secondly, No.0199 is the only wagon I've seen with that white square between the I and S, which I represented on the correct side. However, as I've not seen this on any other LEWIS wagon, and as I don't have a photo of the other side of No.0199 to prove or disprove its presence, I have omitted it to represent the wider fleet.
All in all, I am very happy with how this has turned out. I've been planning this one for a while for the somewhat nerdy reasons I stated at the start of this build, so to see it finally realised puts a smile on my face!
Equally, I can highly recommend Meon Valley Models wagon kits, as the print quality is beautifully crisp and, when paired with a brassmaster chassis as designed/intended, it runs like a dream. I shall definitely be utilising these again for other PO wagon builds.
Speaking of, I have two PO wagons already lined up, and plenty more I'm figuring out, but before that, I owe someone a pair of cattle wagons. Keep an eye out on
@Herb Garden 's thread for as and when I (re)start that project...
- James
