In ignorance, and knowing nothing of NA railways... I'm familiar with cadence traction control and braking. However, as you've described this, Mick, with wheels apparently designed to skid on the rail head to a greater or lesser extent there must be considerable wear to the tyres and rail head. I know from chats with the PW chaps on the GC that they get very upset when they see driving wheels skidding as trains leave stations - an entirely different concept I realise. It may be, of course, that the replacement costs of wheels and rails are offset by the economies of power/speed/acceleration but you have successfully created a curiosity bubble here at Dale Towers.
Yes there will be wear, but if you have seven units per train and can dispense with one or even two to haul the same load then the cost savings are worth it, those units can then be deployed on other revenue services earning money, also on the big spreadsheet in the head honchos office you can reduce your overall number of locos.
I can't find an exact cost for a GEVO today but they were $3m ish in 2010 so lets say $5m today, you can do a lot of wheel turning and rail grinding if super slip saves say 100 (conservative....very) less locos on the books.
Slipping is different to skidding, slipping is a smooth linear wear over a given distance, skidding is a localised point wear and creates flat spots on the wheel rim, flat spots are bad and only get worse, they can in extreme cases cause rims to split and collapse, they also impact a shock to the rail and truck with every revolution and when the train brakes next time the wheel will momentarily stop at the same spot and make the flat spot even bigger.
Slipping on the GCR is almost certainly a steam engine, slipping on steam engines is almost totally out of control, the risk there is not damage to the track or wheel, but to the motion and often catastrophically. Having said that, slipping at a stand still will wear a flat spot on the rail (the inverse there of) and damage the rail head, there's been some monumental slipping on SAR iron ore roads I've seen where a drunk driver has let the engine slip for hours and almost ground all the way through the rail.
One other aspect, only the rail head is strengthened/hardened during manufacture, the rest of the rail is just normal steel, once you get through that hard skin on top you'll chew down through the rail real quick. Our cranes I went to in China had the same (trolley) rail as Australian light railways (P75 profile if I recall correctly) We had to cut test sections out and then pin point hardness check different areas. The running surface was much harder than the web and foot (however the rail also had to be harder than the wheel, the wheel is the sacrificial part of the mechanics, as it is on locomotives) thus we had to non destructive test all the wheel rim hardness as well.
And yes, we had skidding and slipping on the cranes all the time and it made a right mess of the rails and wheel rims, again DC motors where hard to control, AC much better at accelerating and stopping loads.
Tests across rail head to make sure it was uniform and dept to make sure hardness extended down to our minimum wear threshold.
Sorry Richard, I'll let you have your thread back
