Peter Insole
Two more sets of points to build............
Watch out Col, I'm just about to overtake you!
Pete.
Pete.
It all depends which year the photo was taken. I think St Leonard’s was 1951, but then for the next five or six years Mr Lane set up his miniature tramway in Rhyl, before settling in Eastbourne for the next ten years or so (where I used to ride on it, as my grandparents had retired there).This could so easily descend into silliness, which is something that I would be terribly disappointed if it didn't happen!
On a slightly more serious note, the ultimate goal of this extension has been the subject of just a little confliction from the beginning: Providing as much distance of rail to ride upon within boundary limits is an obvious attraction, and indeed, there is at least one significant operational benefit of being able to do so. There are however two distinct difficulties that I have with that. The first, and perhaps the minor issue of laying steel rails in concrete alongside the driveway is both a preference and at the same time an absolute necessity. As previously discussed on this thread; completing the final section of line with the same 16mm aluminium rails as the rest, in an area that must be shared by motor vehicles, and a heavier footfall, dictates a more durable, inset tramway type construction, but I also have a nagging fear that aluminium is rather attractive to scrap metal thieves - whilst the tops of thin strips of rusty steel might be marginally less so? Apart from that, the second point troubling me is perhaps more a case of perception? I cannot help feeling that if I were the Duke of Westminster... or at the very least an obviously successful, retired businessman, my interests and activities might be politely regarded as mere eccentricity - whereas I am clearly not - in which case similar behaviour might more likely be seen by the population at large as peculiar, and dare I imagine, even slightly dangerously so?! What people do in the privacy of their own homes and gardens may be tolerable to some extent, but I am afraid the moment those rails appear from under the gate - and into the full glare of the public gaze...(?) will I have crossed some form of Rubicon?
I have not particularly set out to seek attention in my local community, but it cannot possibly be avoided once the deed is done... and of that I am quite certain!
The Devil may care side of me is still winning though, and in reckless fashion, work on the "ladder" construction has commenced - regardless!
View attachment 240908View attachment 240909
In the end I decided to use M6 threaded rod for the "rungs". Not up to my usual belt and braces approach I know, but the size of the bar and size of the nuts fitted thereto determined that as a maximum to allow sufficient depth and flange clearance.
There was a bit of amusement to be had drilling consistent holes in the long, and quite unwieldy bars!
The "tie rods" are rather slender affairs, but I draw some comfort in the belief that they should only really be required to provide gauging - mainly during the pour and puddle phase of laying in the roadbed?!
That is the main, straight length ready... with the remaining half length needing an awkward curve bending in still to do.
A wagon sent down it for a test roared terribly, almost frightening my witnessing wife! I attempted to assure her that the noise was somewhat accentuated by the track being only loosely laid atop the path slabs!
It should, I trust be a little quieter when solidly set?
Hmm, who am I kidding? A seriously common complaint about trams was that they not only made an awful racket when in progress, but the fear that vibrations caused structural damage to nearby properties!
I do believe that was a factor that a certain Mr. Claude Lane discovered years ago, when the local authorities reacting to similar pressures, evicted him and his wonderfully glorious miniature tram from the seafront at St. Leonards?!
copyright image shown here for reference (inspirational!) purposes only.
In which case, if it is true; there's surely nowt as strange as folk... and I stand little chance!
Pete.
I just had the thought of a car decked out as a train ferry.....I don't really miss the act of driving, and certainly not the appalling cost these days of owning and running a motor car, but I do feel the loss of independence at times. One area of occasional frustration is obtaining materials for the railway, at least in the familiar manner that I am comfortable with anyway!
Choosing a particular mix of concrete for setting this last tramway section of the extension has been the cause of some concern for a while, and among other things, I have perhaps foolishly been thinking of every method and means to reduce construction expenses and complexity on the (not insignificant 30') length required. Ideally, having chosen to use threaded rod rather than any other form of sleeper/ties, I should have taken the opportunity to add a form of check rail - primarily for making the process of levelling the mix between the running rails a bit easier, but also for maintaining a more secure and clean edge for the flangeways. Unfortunately, a degree of laziness, a fear of the effect on a dwindling bank balance as well as freshly painful memories of the difficulty experienced forming the curves have all had a distinct impact on my decision making! I would rather simply drop thin strips of timber (any old reclaim will do) inside the rails during the laying process, something I have done in an inverse way before when making drip courses under cast in situ concrete windowsills. I know that in the longer term, wear and tear, plus the natural effect of weather will untidily damage those flangeways - but I'm prepared to live with that. I am also aware that conventional concrete "ballast" consists of mixed size and some broken stones in the mix. As such muck erodes, it can leave particularly nasty, and potentially injurious edges. Whilst the inclusion of sharp aggregate is doubtless for good reason, I would much prefer to use something like "Pea shingle". Scattering shingle on top of wet cement in "Pebbledash" fashion was briefly considered, but is perhaps not really an option - as over time the stones are liable to break free and leave a peculiar, patchy, miniature lunar landscape in their place?
Surprisingly, or perhaps not so in this age of internet shopping, I find that fine aggregates - indeed almost any come to that - are notably unavailable at the dwindling number of local builders' merchants in our district, so I find myself frustratingly reliant on the goodwill of others for transport assistance!
Laying a hard and carefully levelled foundation in a deep trench, with the rails set out on top once the mix has sufficiently hardened, thence followed by a covering, decorative layer is undoubtedly the best method, but as part of the formation alongside the the original paved area has a brick wall just below the surface on one side and well compacted hardcore, with a thin, levelling layer of sharp sand on the other. Digging that lot out would be a serious task, and otherwise, ending up with what would in effect be two thin cement layers (base and top coat) would be equally unacceptable.
I decided in the end to leave everything alone below and support the rails at the required height with a series of cut bricks, blocks and pavers, while using bits of broken tile and slivers of slate for precision. The whole assembly is somewhat fragile, but a hard mix of plain mortar "dollops" packed all round the columns and bottom of the rails should be sufficient to hold it all in place until I have acquired the right materials for the main pour - shingle or grit and all.
View attachment 241529View attachment 241530
Beyond the paviours, the whole area is made up of quite deep, well smashed and tamped hardcore, so I am trusting that maintaining a 4 to 5 inch depth of concrete, that to some extent is reinforced by the set in rails and ties themselves should be adequate?
The "road" will be contained by the reset original blocks, and a batch of new to complete the hardstanding, laid firmly up to the edge as well.
It will be interesting to see how it fares?!
Pete.
Doesn't that class as thinking about it...Coming along very nicely there Pete. I am so enjoying your tales from the trackside, thank you.
We would need a rack and pinion effort in our garden as there is quite a slope.
No, I'm not going to even think about that.....
