A British H0 Miscellany
MB-24 no.5 (Matchbox / Bachmann)
RichardG
A while ago I developed a British H0 habit. This was only loosely “British” because I considered anything which ran in Great Britain (including Continental outline subjects) and even subjects which were physically small enough to run here but never actually did.
I have been looking through my photos and it seems sensible to share them here. Many of the photos appeared on RMWeb but got lost, while the narrative here is new. In very broad terms, the models ought to be able to populate a modern scene with a local preservation society on-board, and such a layout is a possible project for me after I finish my 7mm scale Heybridge Railway.
My first loco conversion was the Matchbox MB-24, this was in October 2015.
The chassis donor is the Underground Ernie inspection car by Bachmann.
The wheelbases are nearly identical.
This is the power unit before modifications.
I gave the chassis new outside frames and a coupler at one end. The springs are Airfix/Dapol railbus ones.
There is enough space to include the cab bulkhead, just.
The body carries the coupler at the other end.
Everything fits together, not much space to spare but later I put in a DCC decoder.
The body colour is Halfords Volvo Dark Grey.
This is about right for H0, but a bit small for 00.
I remember I bought the source model on eBay for £1 plus postage. The result still runs really well. With its tiny wheelbase and rigid chassis this loco out-performs models which have cost me a lot more.
RichardG
I had two goes at the DCC installation.
The first attempt used a decoder from DCC concepts.
This came with its own stay-alive.
One day the decoder packed up and I put in a Lenz Standard V2 instead. This is using the same stay-alive, this being hard-wired onto the bridge rectifier. Everything here is still working fine.
The Lenz V2 has proved very adaptable because it has a choice of six pre-set characteristics for different types of motors.
RichardG
This is SMP type J track with the ends of every sleeper trimmed about 0.5 mm. The result is pretty much a scale model of British BH track.
The gantry is from the Kestrel kit but with the crane completely remodelled to make something closer to prototype practice.
I have half a dozen locos and as many wagons which I can post here, so I can wait awhile and see if any discussion begins before moving on to the next.
What is the wheelbase of Underground Ernie's drive mechanism?
Just thinking it may also be useful for conversion to O gauge short wheelbase industrial electric locos.
Please keep the HO stuff coming.
If I were modelling British, again, in the smaller scales, HO would be my preference as the RTR track is the correct gauge and you can freely interchange Roco and Liliput Fährbootwagen without it looking ridiculous due to the 3.5 / 4mm scale difference.
Which remind me I need to find some Fährbootwagen for my DB Layout.
RichardG
25.4 mm, which somehow sounds much more precise than one inch.
The wheel diameter is 9 mm.
I spent a lot of time between two stools, not ready to decide on a modern railway or something set in the 1960s/70s. I packed all of my ferry wagons away into their boxes a few weeks ago and somehow the big picture now looks clearer: a modern railway and some kind of adjacent preservation operation.
If anyone would like a few Fährbootwagen or even quite a lot do drop me a PM and I'll compile a list. There must be at least a dozen packed away, they include DB DR and one Belgian.
Yes I will, but let's see if anyone would like to comment on "MB no.5" or indeed the ferry wagons or something else.
timbowales
That little beastie is strangely reminiscent of the Tri-ang Dock Shunter
BR class 42 'Warship' (Fleischmann / Ultrascale)
RichardG
The Fleischmann Warship models are now over forty years old. They seem to run really well or barely run at all - I bought one of the good ones. I decided to fit mine with Ultrascale wheels and these I recall took ten months to arrive. So I reworked the model in stages spread out over more than a year.
This is Fleischmann’s original coupler. It looks like a tension lock but it doesn’t couple up to anything except another one.
This is a Kadee with an over-set shank, fitted onto the loco in its original condition.
I lowered the chassis onto the bogies when I installed the Ultrascale wheels.
The lowered model needs Kadees with a centre-set shank.
I shortened the draught gear box to clear the motor. I glued the original driving gears onto the backs of the new wheels and somehow these have stayed put ever since.
Incredibly, the Ultrascale wheels are so thin the lowered model still negotiates a Radius 1 curve. Though this is somewhat academic because the bogie stock it can haul needs Radius 2.
This green loco ran really well too but I decided one was enough and sold it. I couldn't face another ten-month wait but the wheel conversion was definitely worthwhile.
RichardG
There is masses of space inside these models to do a DCC conversion. I left the unused wires coiled up for directional lighting which I never did.
Again, the Lenz Standard V2. One of its motor drive characteristics suits these can motors well.
The power unit soldiers on.
This "layout" was a six-foot siding with a detachable scenic section hung on the front.
RichardG
Despite being over 40 years old the Fleischmann Warship body moulding is very finely detailed and still stand up well (if not better than) today's 4mm offerings.
I think the shape is right and the proportions are right. I mean, the model looks like a Warship.
I took the coupler off at this end because I realised I only every ran the model light engine or with one or two older wagons. Like the prototype, the lack of an air brake rather limits what I can put behind it.
I took a completely different approach with my Warship and used the trucks from a Roco V200 chassis I was given as I wanted an all axle drive. I ordered replacement traction tyre-less wheelsets direct from Roco spares and, like yourself, I also lowered the ride height at the same time.
It did mean bit more work on the chassis and body mountings to accommodate this as well as the red/white directional lighting PCBs. It has an ESU Loksound decoder with the V200 sound profile.
I finished it as at the end of it's green days with the OHLE warning signs and small yellow warning panels.
And from our low photograph angles it looks like you can almost see through the engine bay grilles - which shows how well Fleischmann tooled the moulding.
GBRf class 66 (Mehano repainted and rewired)
RichardG
I cannot help thinking the older models were far more adaptable than the offerings of today. The Mehano class 77 for example has a solid lump of a chassis filling its insides - you get what you are given and modifications are really awkward.
I bought this one brand new and decided on its livery later.
There are two body styles for a BR class 66, with four or five doors. This one has five.
Photographer not confirmed, possibly Andi Walshaw. Unfortunately I've lost his contact details.
The three GBRf locos numbers 66 747, 748 and 749 are a good match to the HGK machine and I settled on the GBRf interim livery applied soon after the locos arrived in the UK. It is a simple scheme and it helps to date a layout very precisely, perhaps a bit too precisely.
The repaint is by Andi Walshaw, this was done in the autumn of 2016. Andi swapped out the moulded cab handrails for wire ones too, I think they lift the look of the whole loco.
These models are DCC-ready but I could not fathom out how to control the directional lighting. There were too many options available.
In the end I detached the lighting connections . . .
. . . and re-attached them so I had headlights lit at the leading end, tail lights at the trailing end, and everything on- and off-able from the usual F0.
The lighting clusters and the buffer heads are technically wrong for British practice. One day I will sort out the buffer heads and put some paint on the strip of styrene supporting the NEM pocket. The lights are too fiddly for me to deal with. This is a usefully powerful loco with drive to four axles and traction tyres on two axles.
BR class 81 (Atlas Editions / Hornby)
RichardG
The BR class 81 from Atlas Editions is out of sequence here but I will post it now to continue the theme of centrally-mounted motors with cardan shafts.
The model arrives on a length of track for display.
I bought a Hornby class 67 to donate the running gear. The Hornby bogie wheelbase and wheel diameters are correct for the class 81 in the smaller scale, but of course the bogie centres are much further apart. The difference in sizes of the body shells gives a clue to the task ahead.
My new chassis is styrene. The cardan shafts are the Hornby ones, much shortened. This creation ran remarkably well with the motor simply resting in place (and an umbilical cord) because of course there are equal and opposite reactions at the two ends. However, I could not pick up the model without it falling apart.
I did some test running with the Hornby pick-ups connected and the body in place, just to prove to myself that this was going to work.
The next task was to transfer the Atlas Editions bogie side frames onto the Hornby bogies.
The two Hornby bogies, with 00 class 67 sideframes (left) and H0 class 81 sideframes (right). This conversion was not difficult and clearly most any British electric or diesel prototype can be modelled in H0 using ordinary 00 or H0 wheels and without running out of width.
The drawgear was the most difficult part of the conversion. I ended up sawing the ends off the original chassis and gluing them on. The screw for the Kadee is reinforcing the join.
RichardG
The chassis does very little work on this sort of model; it is only holding the motor and the bogies in the right place.
Nevertheless, with the main dimensions set and a working mechanism I added some sides to reinfoce the structure. These are inclined inwards to try to add more strength.
The drawgear casting offcut just clears the bogie.
I added all of the underframe details . . .
. . . and then simplified them to make space for the decoder.
I added some lead above the driving wheels to improve traction.
I could now see a result.
By now, the moulded pantograph was the weakest part of the model so I bought a better one.
The replacement pantograph completed the model.
The finished model.
Right now I have managed to lose the model (how?) so I cannot take any more photos until I find it. The loco ran very well with its Hornby innards. It is not terribly useful for any layout I want to build but I am glad I tackled it. I sold the rest of the Hornby donor for spares and got back almost all of the original outlay.
LB&SCR E1 (Dapol modified)
RichardG
This is a LB&SCR E1 which I made from a Hornby Terrier. Geometrically, an E1 is about 15% bigger all round than a Terrier, and 87/76 (or 00/H0 if you prefer) is about 1.15, so the rebuild is limited to the height of the cab and detailing.
I shortened the cab by about 2mm and added some 00 window guards from Mainly Trains.
The bunker is extended (because this is one of the Isle of Wight locos) and filled with lead. The lead turned out to be a mistake because I ended up with nowhere to put a decoder.
The toolbox needs to be wider and the middle got filled in later.
A smokebox full of lead, a front fairing and an extended smokebox door.
I altered the front sandboxes to give them a new shape.
The completed model.
Never underestimate the covering power of Halford's grey primer and Volvo Dark Grey.
Few people would tackle a Terrier in H0, but a larger engine with splashers is clearly practicable.
This loco never ran particularly well. After a while I removed the motor, and it now runs in topped-and tailed preservation trains.
I also used the Hornby 67 as a donor drive for my AL1/Class 81except I cut it around a bit to accept the cl.67 drive trucks. I also strengthened the chassis with brass angle which I drilled and tapped to mount to the chassis.
I didn't like the Hornby cl.67 steamroller pizza cutters and thought re-wheeling would be easy - not a chance as although the axle was 2mm the ends where the wheels were mounted were about 1.8mm. In the end I cut new axes from 2mm steel rod, remounted the final drive gear and re-wheeled with 14mm coach wheels.
Yorky D's Küchentisch - Jonny half-a-job...
Other details were new windscreen wipers, new pantograph and rainstrips above the cab doors.
RichardG
I remember the original pressed steel chassis on the Atlas class 81. I could not find anything to cut through it to make the spaces for the Hornby bogies. Nowadays I guess I would try a slitting disc and a file.
Ex-BR class 11 (Roco modified)
RichardG
My last loco to post here is a former BR class 11, this is from the Roco model of an English Electric shunter used on Dutch Railways.
Most of the modifications to the body involve removing unwanted detail.
One tool box is shortened.
I used the first coat of primer as a witness coat while hiding the worst of my changes.
The only new details are the handrails.
The wiring for the decoder rather spoils the look inside the cab. One day I might have another go but the pcb is always going to be visible. This decoder is another Lenz Standard V2.
I copied the livery from a photograph of a similar loco being unloaded at a preserved railway.
When I started in H0 I went for Kadee couplers. Then I realised the RTR stock with its NEM pockets on cams needed a rigid coupling to make the close-coupling work properly. So at the moment I have Kadees on the stock for the local preservation society, and Roco Universal ones on the stock for the revenue-earning railway. The Fleischmann close coupling heads create a slightly tighter gap between vehicles and I might end up going for these eventually.
