Compensation is fine for locos that move slowly but springs give a superior ride to fast moving trains.
Took a wee while, and to be honest, I’m still not sure what the problem was, but both pony trucks now behave themselves. I simply put the reamer in the lathe and ran the pony trucks on and off it repeatedly with a little “swashing” until the problem went away.
It may be that there simply isn’t enough load on the pony trucks, and I wonder if that might not be a good idea also to prevent the nodding dog effect - it’s not obvious when driving the loco sensibly, but a sudden stop does cause a little porpoising. I’ll ponder this.
I might get the brakes done tomorrow, that and shorten the front crankpins, as the following stage is to re-fit the cylinders, slidebars and motion brackets, and the sandboxes. Then a re-spray of the chassis.
I’ll also take the opportunity to 3D print a new speaker box, and hopefully it’ll all be back together at the weekend.
But I’m not holding my breath!
I haven’t clicked muting the sound when filming, so I apologise for the C4 news soundtrack in the background.
The only way you could do it, is if you made fulcrum points adjustable horizontally.....With individual springs it is relatively simple, but time consuming, to individually adjust the weight carried by each axle. Just how that can be arranged with a single spring wire I haven’t figured out....
abc gears, Brian does quite a comprehensive explanation on suspension in the download section
Ken
this seems rather complicated in comparison to the excel spreadsheet I used.The only way you could do it, is if you made fulcrum points adjustable horizontally.
"... Adjust values of a, b, c, d..." in the example shown above
(where I have changed spreadsheet by using different "Axle loads")
The values for a, b, c, d are the original ones where "Axle loads" assumed were all equal.
This is not easily done for the usual method of construction that solidly solders fulcrum points to the chassis.
Hence the importance of getting the calculations correct in the first place.
Alternatively fix fulcrum points such that they are removable? to allow adjustment...
Ian this must be the most telling thing I have ever read about suspension.
0-4-0 locos are usually shunters, so we don't find much written about applications of CSBs to them. Eight- and ten-coupled locos are working long trains on a main line, hopefully at some speed, and setting up four or five pairs of springs will be hard work. This leaves six-coupled chassis open to the greatest amount of debate, and British loco modellers build more six coupled chassis than the other arrangements.
It seems all well and good if you have an existing model you want to upgrade but how do you determine the CofG of an unmade kit?
Or the total weight of a scratchbuilt loco before you start it?
It is almost as if you have to build it rigid to get the required data and then convert to CSB?
Am I missing something here? (The answer to that is probably yes but I just don't know what).![]()
