Buckjumper
Fantastic!
So remind me again, how many of these wagons are you batch building?
) to try it out.
That's a great bit of scratch building - it looks very impressive. So in no small way I'm very reticent to suggest it but it's too clean!!! Dare I suggest a few judicious strikes with a blunt chisel from the rear to give it that well used in service look, something which I think would be a lot easier to achieve with a metal body rather than a plastic body.
The body's done
Right or wrong, those brackets look the bees knees - a pity that you did not photograph the production of the two parts.There's little evidence of how the hinge rod at the door end is attached to the sides. Nothing is visible on the outside. but there is a plate of some sort attached to the top. I assumed it is a bracket, and made a pair up...
Your model is brilliant.
A short length of double-sided tape stuck to the worktop, cutting mat or even the drawing can be used to provide anti-sneeze measures for small components like this.One sneeze and you've lost them![]()
A really great looking result, I shall look out for it in the yard when I'm next trainspotting at Heyside
. Great work Richard
