Richard Gawler
I have given the model the mildest of refurbishments - I have removed the surface rust, blackened the buffers, darkened the wheels, and fixed the loose parts.
The model represents a van built to Diagram 360, fitted for working in express passenger trains but without a through steam pipe, and there is a detailed discussion of the livery here. The source would have been Slater's kit number 7024.
Richard Gawler
If it was being used for delivering forged track spikes from the Black Country, could one say it was conveying the staple traffic of the Heybridge Railway?
This quote is too good to leave behind elsewhere :D
Unfortunately, such a large consignment of track spikes to an existing railway raises problems with logic unless of course they were for the proposed Goldhanger Extension to the line which rattles around in my mind from time to time but which, perhaps mercifully, hasn’t yet made it into WT in any detail.
We know Heybridge Basin handled imports of timber from Scandinavia. I haven’t found out about a return traffic, so I suggest this van is carrying woollen garments made in North-West England and destined for export to Scandinavia. Transhipment being at Heybridge Basin. The use of a fitted van may be simply because this is what was available; or because the shipments need a “just in time” service to tie in with irregular sailings.
I will try to remember to make some spare spikes, to put in my PW wagon :)
GER 10 ton van (1910) - buffers and completion
Richard Gawler
So this is how the model will look for a while, posed here between my Peco/Parkside NB van and my Three Aitch MR van. I have built this GER van entirely from the kit, except for the copper wire between the brake hangers (I had to destroy the piece supplied in the kit during a rebuild of the brake gear) and of course the Slater's wheels.
Six months after I first put my GER 10 ton van onto the track I have tracked down some suitable buffers.
These are GER wagon buffers from Haywood Railway. They are an upgrade from the cast white metal ones supplied in the kit, and I think worthwhile.
The axlebox further from the camera is filled flush with epoxy glue but this dries clear. This model is probably structurally complete and ready for painting now.
Rebalancing the Wagon Fleet
Richard Gawler
Isn’t Brymbo a bit out of area for your railway?
The balance will get better as I build more wagons for businesses in Essex and neighbouring counties.
I have done a little re-balancing of my wagon fleet. The Brymbo wagon jars in my mind. I am pleased with the brake gear but somehow, the combination of unprotypical model and distant operator seems that bit too wrong. I would probably keep it if it was a better model or a more local owner. At least I know what I did to the brakes, the photos are on WT, and I could do similar rebuilds to different models.
I said goodbye to my GWR Hydra a while ago. This was a scale model and suitable but I couldn't devise a sensible load for it to bring to the Heybridge Railway. So I suppose I am doing fairly well if I have built 14 wagons and only let go of one.
I bought some 9ft sleepers from a modeller in Devon and discovered he wanted to downsize his GER collection. So I could hardly resist these . . .
According to Tatlow (LNER wagons vol.1 p.188), the GER built 3,000 four- and later five-plank wagons to diagram 16 during the decade to 1895. So this model fits my the layout perfectly. I have a Mystery Load too, if I try using playing cards for operations.
I don't know about the drop side wagon yet. Studying Tatlow, it looks as though these didn't make it into the LNER. But drums of electric cable could be making their way to Bentall's factory or, via the navigation to Chelmsford.
The GER painted these wagons slate grey and this is usefully different to the greys of the wagons belonging to the Heybridge Railway. Thank you Peter.
As far as rebalancing goes, I now have three GWR wagons instead of four, and three GER wagons instead of one, and I have gained two absolutely beautiful models to do this. Good.
Standards for Building Plain Track
Richard Gawler
I have had a go at making some flat bottom track using code 100 rail from Kalgarin and 9 ft sleepers from C&L. This was a trial to find out how much the appearance would differ from Peco’s bullhead flexi track, and to end up with something to stand my Y14 on inside its display case.
This is the first time I have used graph paper for years. The sleeper pitch of 7/10ths inch represents a scale 30.5 inches. The code 100 rail is representing 60 to 70 lb/yard prototype.
The gauge is the wanted 31.5 mm at one end and almost 32 mm at the other end because I made an effort to hold the rails down onto the sleepers but no effort at all to push them sideways against the gauges. I cannot see the difference.
I would have rather have no spikes than overscale spikes but I am still searching for something reasonable.
So, a marked difference with the flexi track. There isn’t any comparison really.
Now, I bought the code 100 rail because I thought (and still think) it looks reasonable under a Y14. It is the largest rail section I want for my layout, though I accept it may not really be strong enough for a Y14. Thanks to Col. (@Eastsidepilot) for his recent note on the relaying of the Middy. Hopefully, running at low speeds won't look out of place. I do think, the 2ft 6in sleeper spacing with this rail has a pleasing aesthetic; it looks “light”.
What I really do need to find out is, how to build this track so I can fix it down onto a baseboard and ballast it without the rails popping off during expansion and contraction. If the layout goes in a car in Winter and the hobby room in Summer then I am looking at a temperature variation of 0 to 30 degrees C.
Perhaps scale 40 ft lengths would be sensible for the rails. Perhaps, all I need to do is secure the sleepers below the rail joints and ballast using a latex-based glue. Perhaps, it would be best to leave the rails as long as I can and spike them all down. Any guidance here would be very welcome.
I have put the sample into the display case, it doesn’t photograph very well in there but it looks much better than its predecessor.
Michael thank you so much for all these notes.
I have just found out (from Four Types of Rail Spikes), a modern spike is 16 mm thick. This equates to 15 thou in 7mm scale, while my 26/6 staples measure 18 x 16 thou. So I will stay with these. I have a household stock of several thousand.
I have two BH turnouts for my first diorama, so if I use these then I need to build only plain track to begin with. This is for the traverser and its headshunt. I have limited space for a layout, so I want to make the fiddle yard look as nice as I can. Maybe, even good enough for model photography.
We discussed spiked track earlier; these two posts mark the start and the end of the posts.
I now have a copy of Peter Paye's book, "The Mid-Suffolk Light Railway" (Wild Swan 1986, reprinted 2003) and this work contains many photographs of the original track at the Middy. Now, I know that these photographs were not taken to record the way all of this track was laid; nor were they taken for the railway modeller. But they do repeatedly show one spike not two on each side of the rails, and rail joints on top of sleepers.
The photograph of Mendlesham Station posted by @Rob R is annoyingly clearer than many photos in Paye's book, but I am still wanting to think, the use of a second spike seen here was done to reinforce things or to realign them, and not as a routine practice. The additional spikes seem to be dotted around without any clear pattern.
The Middy was laid with 56 lb/yard rail and I am using code 100 rail which can represent 60 to 70 lb rail. I could claim my rail represents 56 lb/yard rail and this was a (fictional) precursor to the standard adopted by the Middy; but it is easier to leave this one open for now. After all, the Heybridge Railway does see a GER Y14, which would want a heavier rail to reduce the likelihood of breakages.
The photographs in Paye's book suggest a spacing of about 20 inches between sleepers; a sleeper is 10 inches wide so the pitch would be 30 inches. This is the spacing I chose for my example track on "Heybridge Basin", because I thought it looked about right.
So . . . I can go for one spike on each side of the rail on each sleeper for the Heybridge Railway. The Board of Trade may well have been unhappy about this, but if so it is easier to write a fictional letter from them to the railway than to double my workload for building the track. The sleeper pitch can stay at 17 to 18 mm (30 inches), and the rail will be code 100.
Or, to put things more succinctly, "my railway my rules"!
I am happier to firm up on things like this because I now know what I need to do for rest of the track. The only big unknown remaining is what the pointwork should look like, and I don't need to know this until after I build the fiddle yard, complete the Heybridge Basin project, and start thinking about a layout for Heybridge itself.
A single spike each side of the rail would be normal for 56-60lb track using imported hardwood sleepers such as Jarrah - very common in the UK. If the sleepers were pine extra spikes would help keep the track together as pine doesn’t grip the spikes well. Pine sleepers would usually be placed closer together to carry the same load. 30 inch sleeper centres would be common on light lines but the sleepers could be 8 or 9 inches wide. 10 inch wide Jarrah sleepers would be overkill on a light line, although if they were available at the right price the would have been used.
Richard Gawler
I have so many books on "railways in the UK", even a book on the subject of "track" (the Jim Pike one) yet none discuss sleepers in much detail. Certainly no details of 8- or 9-inch wide examples.
In fact, I found more specifications at a supplier of garden landscaping products:
More technical information about railway sleepers - Railwaysleepers .com
This includes data for imports and exports of sleepers for many countries.
Historically, the Chelmer and Blackwater Navigation carried timber from Scandinavia transhipped at Heybridge Basin; but Swedish sleepers (as an example) were different again - cut top and bottom and wavy edges on the sides.
So for simplicity, I am going to suppose T A Walker Contractors had a quantity of imported hardwood sleepers left over from another job, and they used these to build the Heybridge Railway. So 9ft x 10 inch sleepers, and one spike each side of the rails.
But thanks Fraser for a most thought-provoking post.
Richard Gawler
Are you using Dinghams now Richard
Only on the two GER wagons I just bought. I have one fitted wagon (the MR 'express' van at the top of this page) and everything else has three-links.
These Dinghams are very securely fitted. Just like my own three-link hooks really. I am thinking, the advocates of springs and split pins for attaching couplings are probably people who have found themselves wanting to swap couplings.
Sleeper-built buffer stop (1) construction
Richard Gawler
I haven't finished a model since the build of the Slater's MW F class last year so it seems like a good idea to try something straightforward and follow it through to completion all in one go. I have plenty of sleepers now so I have made the buffer stop for the goods yard at Heybridge Basin.
Sleepers glued onto 1.5 mm mount board. One sloping side here needed a mirror image and had to be re-done.
The model is fairly square, but not spot-on.
The important thing for me is to make something sufficiently uneven to look as though it was build by people not a laser, but not with so much slack it looks sloppy.
This is my first attempt at a "robust" scenic model in 7 mm scale. I hope this is good enough but if others have seen similar structures fail in a rough shunt then do say.
Posed at Heybridge Basin.
Sometimes it is quite satisfying to see a rapid result. This model only took one evening, plus a few minutes the next day to fit the top and arrange the carboard packing underneath. Painting can follow after I have built a few more scenic items.
Tim Birch
I agree that pottering around with simple 'natural' materials can be very satisfying, and relaxing. I recently made a shunters' cabin from a drawing in a book. The carcass is cardboard and it is clad with 4mm point work sleeper strip from my EM days. 4mm sleeper strip make very good 7" planks in 7mm scale.
Richard Gawler
I will be on the look out for this. I have discovered, the laser leaves a slightly angled edge. If the material is thick enough then butting parts up against each other leaves a consistent narrow gap. No need for slips of paper or similar to set up the gaps between boards.
Tim Birch
I see that the EM Gauge Society sells 4mmx 300mm sleeper strips in two thicknesses in bundles of 50 for £8.50. As mine had been is stock for some time, they had been knife-cut from ply sheet. The current stock is stated to be laser cut. I think that they are only available to members, or at shows. The next show is the annual show at Bracknell on 11 and 12 May, or alternatively the summer show is in Wakefield on 17 and 18 August.
Yard crane New
Richard Gawler
I can see two ways to continue this workbench thread. I can either try to paint the buffer stop (and each successive model) or just carry on with the building. I’m not very good at painting (might improve!) and I am waiting for warmer weather to spray primer outdoors, so I will carry on with the building . . .
Rewind to last January:
I am building the Peco yard crane in 7mm scale. Their p/n LK-735.
Please, do we know whether this is a model of a real crane, or perhaps an amalgamation of a few different prototypes? Then I could tweak the model before painting it. Searches are (unsuprisingly) bringing me only adverts for the kit.
The yard crane for Heybridge Basin is from the Peco kit. I have shortened the jib a bit so the model looks better in the scene, not for any prototypical reason.
I have based the jib on a crane preserved at Ellesmere Wharf on the Shropshire Union Canal. The steel girders provided for the jib in the kit are wrapped up inside the white styrene to represent a timber beam.
I have added a brass spindle to attach the two stays. This arrangement seems to be more common than fixing the stays to the frame holding the pulley, as portrayed in the kit.
The rollers for the chain are brass wire, tube and 14 BA washers.
This all comes apart for painting.
I have picked up a particularly stupid habit of dipping the brush for Plastic Weld into the bottle of phosphoric acid flux, this being followed by pondering why the plastic joint has fallen apart. Also the brush carries contamination onto the model, hence the stains on the jib. Hopefully the primer will still stick :rolleyes:
spikey faz
That's OK, as I have unsuccessfully tried to solder using Mek-Pak as a flux! :eek:
Richard Gawler
This is all giving me great confidence to have a go myself……
Well, don't read too much in me taking three months to build this kit! I convinced myself I wanted a timber jib, but most of the photos I found showed an octagonal cross section and/or pronounced tapers at the ends. Difficult to make.
I only got going a few days ago when I found a photo of a jib with a square section and no tapers. Then I combined this with the rollers seen on the crane at Elsemere Wharf, and "made something".
There is no single prototype for the crane I have built, but I think what I have done is more suitable for my Victorian canal basin than the H beam jib provided in the Peco kit. Conversely, I doubt I would have built any crane at all without the kit. The kit provided all of the intricate parts and got me started.
Water column New
Richard Gawler
I have assembled a water column for Heybridge Basin from a Duncan Models kit. This column is described as GER pattern but the design is so plain it ought to pass as generic.
The plywood base is something solid to fix the column onto. I can build up the surrounding ground level with foam board or similar.
The kit provides a base with detail of what I think is stone setts. The grating is a cab grill made for 4mm scale.
The idea of the card underneath is to let me prise the model off the baseboard if I ever want to re-use it somewhere else.
The model will have to stand quite close to the railway if the hose is to reach a water filler in the middle of a loco.
I’ll put off making the hose until after painting. The stash of unbuilt kits is diminishing but I am gaining a collection of almost-but-not-quite-finished models in its place.
