Think I'm still in pottering mode, rather than grafting, don't feel I've achieved much today despite spending all afternoon / evening on the layout. The Ground Frame has had a wooden surround made for it so it can be removed for transit, the surround will eventually be stuck to the layout with the ground forms around it. The front most plank will need to be stuck to the GF itself, I'm not quite sure what I'll do with the foot board to go on the rear, probably something similar. It'll get a bit of staining tomorrow once the glue has dried completely.
The ground disc has been built from a MSE kit but seems to have aquired a slightly forward lean when soldering to the base plate. Ah well
I've built up a signal wire carrying post as well, although its highly unlikely there will actually be a signal wire, it just adds another little bit of interest. All of the bases have been cut down to size and glued into place, the rodding runs and ground disc gaining some small pins so I could apply Tim's hairshirt method of fixing in place.
And last of all, the turf got slung down on the removeable sections and the platform gained a stripe.
Tomorrow will bring more painting, maybe a bit of grass, some ground forms and if I can face it, I'll build all the point rodding so its a job off the list, they'll be fixed into place after painting and ballasting.
Steve
